How many remotes for various implements and what use 1000 rpm?
   / How many remotes for various implements and what use 1000 rpm? #21
As far as remotes. Get as many as you can. While you will never have too many, you certainly can have not enough. Just make sure the connection are the quick connection types.
   / How many remotes for various implements and what use 1000 rpm? #22
Hi
> If you go with T-N-T, (top and tilt) that's a hydraulic top link and side link
> to a lower 3pt hitch arm, there's two remotes used. I would get Three.
> Back Blades can have three, tilt, offset and angle.
What are back blades?
> I think the 1,000rpm PTO is used when greater HP has to be transmitted.
Ah so its not for something that has to spin very fast but for more power. Thats means with me getting a 60 HP machine, mainly for brush hogging and lifting things I wont need 1000 rpm.
> What do you mean by TPL?
Three point lift. I have modified my post avoid the TLA, three letter acronym :)
> Backhoes normally require PB (power beyond) since they have so many
> functions.
Ah had not heard of PB before, Googling it shows lots of stuff to read there on the tractor forums and on here. Have learnt another term now.
Mike
You are correct, three point lift does not require any remotes, it's hydraulic system is built into the tractor just for it.
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A52576)
LINK BELT LB-98...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
80in HD Tooth Bucket with Side Cutters (A53472)
80in HD Tooth...
2002 Western Star 4900 T/A Galbreath Rolloff Truck (A51692)
2002 Western Star...
