how meny have fels
   / how meny have fels #61
I have 2 tractors and both have FEL. They come in handy for helping you get out of sticky mud also. One tractor is a 50 horse and pushes down small trees with ease and the other is 72 HP and can push down fairly large trees and carry a really big rock.
When my brother in law suggested that I should get a FEL on my first tractor (he didnt have one then on his 750 JD) I said why, I grew up on a farm and we never had one or though we had a need for one in the row crop business. Then after owning the small Yanmar for a couple of years I saw the value of one so when the wife said" you should get a tractor with an Cab and AC", I wasted no time getting the CAB with heat and air AND a FEL. If I ever think I need to do something that I won't need the FEL, it can come off quickly but I just cant think of anything that I do when I just might need the loader.
   / how meny have fels #62
I have always had a FEL on my tractor. Takes care of all the lifting and carrying about which is about half of the work I expect from the tractor, plus some grading. It has to be detachable as I have a lot of work to do around trees and in places with little space to spare. I now have a JD QA which does the job perfectly.
   / how meny have fels #63
I have a FEL and wouldn't have a tractor without one.
   / how meny have fels #64
I've got one on my Yanmar,plan on getting a tooth bar soon.also have pallet forks. russ
   / how meny have fels #66
i think it all depends on a lot of factors. my family had cattle when i was growing up. there was an early 70's tractor with a loader, and an old 50's one without one. in the 80's they added a new 4wd tractor - no loader. the reason being was that it was mainly for use pertaining to the farm. they could always get by with one loader. there was really never a time when they needed more than one at once. the tractors were mainly for equipment operated off the rear of the machine - rotary mower, mower/conditioner, tedder, rake, bailer, skidding winch, post driver, etc. i think if you use (not collect) more than one tractor in a farm setting, you can probably get by without them on every machine. having one is almost a necessity though.
   / how meny have fels #67
the 2305 I just got rid of is the first tractor I've had with a fel, won't ever buy another without a fel. A fel doubles the usefulness of a tractor.
   / how meny have fels #68
Without the loader I would have no reason to have the tractor so FEL :thumbsup:
   / how meny have fels #69
Not me. My reason was the research I did before buying a tractor. I found WAY too many instances's of front gears trains being broken. Transmission cases/ flywheel housing being busted. Tractors literly being broken it two pieces.This happens across all manufacturers. I could never afford a catastrophic accident such as that. NO FEL for this operator. I've managed to do everything I've needed to do without one. I did however rent a small tractor backhoe / FEL to dig a water line in, that was about four years ago. I'm happy all you guys have one, They are just not my cup of tea, thankyou. bjr
   / how meny have fels #70
Interesting, in the 50+ years I have been driving tractors, I have never run across that.
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
WESSEX CRX 240 LOT NUMBER 169 (A53084)
WESSEX CRX 240 LOT...
Caterpillar Loader Quick Coupler (A53472)
Caterpillar Loader...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2005 GMC Sierra Pickup Truck, VIN # 2GTEK13T851399344 (A51572)
2005 GMC Sierra...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
