How much do you think this stump weighs?
   / How much do you think this stump weighs? #21
I have been able to pick move larger stumps by just workinig at knocking the dirt out of the roots. The dirt is what makes it heavy. You just have to keep picking at the roots. I'm suprized you tried using the loader vs. working it out with the hoe?
I would have use my L39's hoe bucket curl force to get it out of the hole or at least knock it around, then knocked the dirt out, and finally carry it away with the front grapple.
Stump weight is really tough to judge.
   / How much do you think this stump weighs? #22
That reminds me of a suggestion that another made for cutting down the weight of the root ball. Use a sawzall with pruning blades to cut pieces off. Be prepared to ruin a few blades but they are cheaper than chainsaw chains.
   / How much do you think this stump weighs? #23
Using a hose or even better a pressure washer to get at some of the dirt in the stump roots can help. If Ms. Tractor allows, you can also just let it sit for a season and let Ma Nature's rain and freeze thaw cycles help you too.
   / How much do you think this stump weighs? #24
See my post in the pics forum. Ray picked up a root ball & simply shook the dirt off it, like you would pull a carrot from your garden & shake it clean! Whoever said, "Size doesn't matter" was wrong! :D
TIRE MOUNTING AIR MACHINE (A53843)
TIRE MOUNTING AIR...
2020 Kinze 3505 High Speed 6/11 Planter (A53473)
2020 Kinze 3505...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A53473)
2023 NEW HOLLAND...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53473)
2016 KBH...
