How much fluid for tire ballast
   / How much fluid for tire ballast #1
Surgeon
Vermont
MF 1428
I know this subject has been covered ad nauseum but I cannot find on any of the websites how much fluid to put in a 12.5/80-18 tire. Any guesses?
   / How much fluid for tire ballast #3
Are you going to load the tires yourself or get a shop to do it?
   / How much fluid for tire ballast #4
12.5x80-18 22.0 235.4
so 22 gallons per tire, and 235.4 lbs of Rimguard.. water or methanol mixes would be less of course. water would be about 176 lbs.
James K0UA
I am going to do it myself. I have a Gemplers fill tool and 12 volt marine pump with garden hose fittings.
I ended up putting in 23 gallons per tire using a Gempler's fill tool and a marine pump. It is like having a new tractor. I had excellent help too!
   / How much fluid for tire ballast #7
I'm confused on the tire sizes on the table. I don't see Surgeon's tire size on that table either. I looked up the tire size for the industrial tires on a CK35 I'm looking at getting which is a 15-19.5 according to the Kioti website. I don't see that one either. So how do you find your tire size on the table?
   / How much fluid for tire ballast #8
Here's some of the Titan tire recommendations. the 15-19.5 is listed
   / How much fluid for tire ballast #10
I'm confused by the difference/advantages between filled tires and ballast mounted on the 3 point hitch?
What differences do you notice after filling the rear tires?
And would ballast on the 3 point offer the same advantages as filled tires, and maybe more?
yellow ball Trailer (A56859)
yellow ball...
2000 FORD F-350 SUPER DUTY (A58214)
2000 FORD F-350...
18' X 20' STORAGE GARAGE TYPE CARPORT BUILDING (A52708)
18' X 20' STORAGE...
Automatic Tire Changer (New/Unused) (A59225)
Automatic Tire...
Schulte SBW800 Rock Windrower (A56435)
Schulte SBW800...
NEW 5/16x7ft G80 Chain Sling Double (A59000)
NEW 5/16x7ft G80...
