How much heat?
   / How much heat? #1
tow653
Gasconade County,Mo
New Holland TC29,Ford Jubilee
Went to change the blades on a Wood RM600 rear finish mower today and couldn't break the bolts that hold blades on with a 3/4" breaker bar,socket slipped. How much heat can I apply to bolt to loosen without seals? Thanks,
   / How much heat? #2
The blade bolts don't have seals so no worry there.
Heat the nuts to dull red and use a good air impact wrench. They will spin right off. But....don't pick them up right away. :fiery:
   / How much heat? #3
Are you sure the bolts are not left hand threads ? Fought the very same problem on a finish mower until I figured it out. An impact will be a lot easier if you have one. Good luck
   / How much heat?
Yes they are left hand threaded ,but knew that and was going correct direction,only have an electric impact wrench,will give it a try.
   / How much heat? #5
You may not have a impact wrench strong -- My 1/2 inch snap on with a huge compressor wouldn't budge it; Moved up to a inch gun and it had to beat on it a while till it moved...
   / How much heat? #6
I've always found penetrating oil overnight then heat will break most anything. Of course, unless I'm twistin' the wrong way.
   / How much heat? #7
What do you mean the socket slipped? Have you already rounded the corners on the bolt? Are you using a good quality 6 pt socket? Whatever is tightest fitting, standard, or metric? I've driven sockets onto badly rusted nuts or bolts before.
Are these nuts or bolts?
Wouldn't heating a bolt to red hot, then spinning it off... only spin half of it off... with very much undesired results. :confused:
Typically one turns the bolt/nut in the direction of the cut to loosen the bolts, and opposite of the direction of the cut to tighten.
When all else fails, try a bigger wrench.
2016 Ford F-350 4x4 Crew Cab Utility Flatbed Truck (A55973)
2016 Ford F-350...
2006 Chevrolet Impala Sedan (A54815)
2006 Chevrolet...
New/Unused IRGC40 Mini Golf Cart (A57453)
New/Unused IRGC40...
2019 Caterpillar 249D Compact Track Loader Skid Steer (A55973)
2019 Caterpillar...
2009 International 7500 T/A Terex Digger Derrick Truck (A55973)
2009 International...
2003 Ford E-250 Wagon Passenger Van (A56858)
2003 Ford E-250...
