How much post hole digger can it run?
   / How much post hole digger can it run? #21
I have drilled hundreds of holes with my PHD and never ...ever gotten it stuck in a hole..All you do is when you want to remove it from the hole you have drilled is keep it turning and lift up on your 3pt lever but be careful since if you come up out of the ground with the auger spinning loose and wild it can go anywhere...keep in mind the hole you are drilling is all that keeps the auger under control, once you bring it up above the lip of the hole ...all bets are off and it will swing wildly so you have to be careful in raising it up as you put the power to it through the PTO..
Ive never had an auger in problem either ... except from catching a root. Usually it just shaves down thru the soil, much like a wood bit. I usually dont clear the hole til the end either cuz the tailings aid down force. With the Mahindra tho I am seeing some bend in the PHD neck due to the hard pull needed to bring it out of the hole sometimes when it has penetrated quickly [almost augering in]. Im going to have to reinforce that neck before I break it!
larry
   / How much post hole digger can it run? #22
larry
Larry, with all the stuff you have and you don't have a down pressure kit for you PHD. I am somewhat shocked. :shocked: :laughing:
   / How much post hole digger can it run? #23
Turns out we dont need that much around here. Hung some extra weight on the phd and seldom have a problem.
larry
   / How much post hole digger can it run? #24
This seems like a good thread to ask in.
I will soon have a JD 420. Yay! More obsolete stuff!
I'm toying with the idea of putting a hydraulic auger on the FEL (mostly because I have a free one available that allegedly works). I know that my tractor hydraulics won't handle that, especially with the clay around here, but are there hydraulic pumps that could be mounted to the rear PTO (2000 RPM)? Would that supply the flow rate I'm looking for?
I know these pumps exist for the standard 540 RPM PTOs, but I've never seen one for 2000 RPM PTOs.
Tank Only (A59076)
Tank Only (A59076)
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2017 Scag Cheetah 61in Zero Turn Commercial Mower (A59228)
2017 Scag Cheetah...
2014 Kia Sedona Van (A59231)
2014 Kia Sedona...
Rooster Weathervane (A55853)
Rooster...
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
