dstig1
Super Member
- Joined
- Apr 7, 2010
- Messages
- 5,514
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
Thanks for the replies. And yes, there are some unknowns that complicate this. I have no way of figuring out how much pressure the broom really needs to run, until I build it, run it with a pressure gage in the line. At which point it it kind of too late to back-up in this case. If I had that, we might be able to work out the rest.
Some Answers
- Use pattern - my driveway and pads outside the house and shop. Driveway total is 1/8 mi or so. Long but not crazy long like some here have. I clear snow with a rear blade and it takes 1-2 hrs, longer if it is deeper or later in the season when the windrows build up and make me plow a lot more to push it back. That is one thing I am hoping from this is quicker clearing and not building up so much near the edge of the drive. It will be running much of the time while I am out there, but there will probably be pauses at times. I am assuming the broom will not work well for big snows, but I may find out otherwise. Rear blade would be the backup plan there.
- Aluminum. I cannot weld alum, so I would have to find someone who can do it, to shift to Ally. Steel is the plan.
-Pump. I already have the pump as I needed that to sort out the mid PTO drive design. It is model GP-F25-39 from this link via Surplus Center:
Here is what I calculated for the pump flow (gpm) vs RPM on the PTO with 2000 being the design speed of the PTO. 2100 rpm is with the engine wide open, so it is unlikely to run in that zone much (I hope...). Sweeper people say it will need something in the 12-25 gpm range
- Prime mover intended for the broom is varied. It could be set up on a skid steer but the manual shows several different configurations possible and this one was orignially set up on a 3pt hitch for a tractor. They also offer a hydraulic pump pack for the rear PTO of a tractor which then requires mounting the broom on the front and running lines the length of the tractor. Some details observed from that are that there is no radiator or fan. They do not say what the volume is, but if I had to guess from the parts diagram, I'd say around 20 Gal. Here is the manual diagram of that:
And, no, I am not buying their kit for this as I need the rear blade on the back. That was the reason I went through the trouble to set up the mid PTO drive. If I went with one tank ~15 gal and later needed to add a cooler, that could be feasible. It might also be possible to add a second tank. I'll show a few CAD images in a next post.
Some Answers
