How much Turbo Boost do you run
   / How much Turbo Boost do you run #11
I do not believe my 06 F250 had a wastegate, but I would only see between 22-30 psi pulling a load. I do have a light foot as diesel was $4 a gallon at the time and as we all know, farming doesn't pay!
6.0 has a variable vane turbo. Its motor is actually a International VT-365.
Chris
   / How much Turbo Boost do you run #12
Chris
That is correct. Thanks Chris, could not remember the name for anything. The one bad thing about that turbo that I recall was more frequent oil changes and the recommended use of synthetic. Dirty oil killed it quick, same with carbon.
   / How much Turbo Boost do you run #13
Never had a drop of syn in both mine. Change the oil ever 5K with Dello 400 or Mobil Delvac. Not a single wrench on either my 04 or 06.
Chris
   / How much Turbo Boost do you run #14
Chris
You change your oil every 5k hence avoiding the extended change (7500+) interval. Oil changes at 5k in any diesel is early, but you are only doing the motor good by doing this. Not knocking you at all. I found when I switched over to synthetic in my 06 it cranked easier, warmed up faster and fuel economy increased slightly. I changed it every 7500.
   / How much Turbo Boost do you run #15
I'm more curious about towing horses at 80mph...? I've hauled horses before; I do not like to go that fast with a live load.
When we took the 5th wheel to Texas two years ago, I could easily run those speeds. However, with this Cummins and 4:10 gears, I found my fuel mileage dropped off considerably above 63mph.
Nice thing about Az, NM, and Tx, was the major highways were in soooooooo much nicer shape than Calif highways...
I was running about 75-80 and pulling 20 to 22 steady PSI on the turbo.
   / How much Turbo Boost do you run #16
How much boost do I run?
Well my 03 6.0 doesn't have a guage so I'm going to answer... All of it.
   / How much Turbo Boost do you run #17
I have thought about it but the simple fact is these trucks never leave with less then 12,000# behind them. That is towing light. Most of the time they have 16,000# or more on them. I would say I am not the norm with well over 90% of my miles towing. I would rather change it more often. Funny thing is I run Full Synthetic in my other stuff like my Nissan Titan. It tows 7,000# to 9,600# 50% of its miles so I split the difference between the normal change interval and the extended change interval.
Chris
   / How much Turbo Boost do you run #19
RickB said:
Manual for a 2001 7.3 PSD specifies a 4000 mile drain interval.
Wow did not know that. I stand corrected. Do you change it every 4k or longer? I thought diesel oil intervals were 7500.
   / How much Turbo Boost do you run #20
The three 7.3L PSD's in the fleet at work all get New Holland 15W40 no less often than every 4500 miles with a 4000 mile target. Total mileage on the 3 is over 400,000 without engine problems.
SDLanch 12'x20' High-End Carport (A57149)
SDLanch 12'x20'...
2014 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2014 UTILITY VS2RA...
SKID STEER ATTACHMENT (A58216)
SKID STEER...
2019 Toro Z Master 3000 Series 52in Zero Turn Commercial Mower (A56857)
2019 Toro Z Master...
2290 (A58376)
2290 (A58376)
(1) HD 20ft Free Standing Corral Panel with Feed Bunk (A57453)
(1) HD 20ft Free...
