How not to skid logs
   / How not to skid logs #32
</font><font color="blue" class="small">( <font color="red"> a come-along for a hoist </font>
The nice thing about this:
http://www.novajack.com/en/0103.htm
is that the log is only in the air when the tractor is pulling. If the log stars to over run on a downhill it will drop and stop. It also eliminates the need for another moving part. )</font>
I like that. It's better than my suggestion.
   / How not to skid logs #33
</font><font color="blue" class="small">( ... Then you would need to reheat and quench to harden the bend (maybe).)</font>
That quench won't do you any good if it's low carbon (aka "mild") steel. You need high carbon steel (or some other alloys which you normally won't find in 1/4" plate without some real searching) in order for the heat and quench to do much of anything.
Also, if you do manage to get some high carbon steel, after the quench, you'll basically have untempered martensite structure, which is very brittle (i.e. it might shatter when you hit a rock, or break with only a slight bend). To avoid this, you'll need to reheat it after the quench, though not as hot as the first heating. The process would be: heat to bright orange color (almost yellow ... this would put you in the neighborhood of 1500+ degrees F), quench before the glow fades, then reheat ... I'd suggest up to the point where it just barely begins to glow (in a dim room, you can see a glow starting at roughly 1000 degrees F). Sorry, the colors are from memory... it's been a few years since I dealt with this on a regular basis. Another thing to watch out for: you'll generally end up with weak spots at the edges of the "heat affected zone". that is, where the portion you heated and quenched meets the portion that was not heated.
All-in-all, a good heat treatment is a bit more complex than is generally appreciated. You might be better off just bending mild steel to the shape you want, then weldng on ribs if it doesn't want to hold that shape.
John Mc
(with too many years in the steel wire industry)
   / How not to skid logs #34
Skid Plate skidder
   / How not to skid logs #35
Trail groomer
   / How not to skid logs #37
I still don't see any attachments or descriptions of what happened. What am I missing here.
   / How not to skid logs #40
You can use "Tempil Sticks" to ensure the right draw temp. Most steels require 700-900F, else it may become too soft. Of course 900F produces a dull red in low light.
2013 ISUZU NPR STAKE BODY TRUCK (A54313)
2013 ISUZU NPR...
Pair of New 700/40-225 Alliance Tires with Rims (A53473)
Pair of New...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
2016 FORD F550 SUPER DUTY SERVICE TRUCK (A51406)
2016 FORD F550...
2007 STERLING T/A DUMP TRUCK (A51406)
2007 STERLING T/A...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
