How not to wreck tire pressure gauge with ballast fluid?
   / How not to wreck tire pressure gauge with ballast fluid? #11
I've used two cheap-o digital tire gauges on mine multiple times and they still work just fine.
Many thanks to all of you for your replies: I shall try them out before starting the hay.
Richardlc
   / How not to wreck tire pressure gauge with ballast fluid? #13
I have one of those pistol grip style inflators with a gauge on it from Lowes. The rubber hose is plenty long so I just make sure the gauge is higher than the wvalve stem and then once done checking I give the tire a shot of air. I did replace the gauge because it went to some extreme pressure, like 160 or maybe even 180 psi with a 60 psi USG gauge but never had a problem with liquid getting into it.
42'x30' Metal Storage Shed (A53316)
42'x30' Metal...
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
UNUSED LANDHONOR PHA-16-2C HYD 3PT HITCH MOUNT (A54757)
UNUSED LANDHONOR...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
SLIDE MASTER ALUMINUM SLIDES (A54756)
SLIDE MASTER...
