How not to wreck tire pressure gauge with ballast fluid?
   / How not to wreck tire pressure gauge with ballast fluid? #11
I've used two cheap-o digital tire gauges on mine multiple times and they still work just fine.
Many thanks to all of you for your replies: I shall try them out before starting the hay.
Richardlc
   / How not to wreck tire pressure gauge with ballast fluid? #13
I have one of those pistol grip style inflators with a gauge on it from Lowes. The rubber hose is plenty long so I just make sure the gauge is higher than the wvalve stem and then once done checking I give the tire a shot of air. I did replace the gauge because it went to some extreme pressure, like 160 or maybe even 180 psi with a 60 psi USG gauge but never had a problem with liquid getting into it.
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
2017 Peterbilt 567 (A60460)
2017 Peterbilt 567...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
Aluminum Alligator (A57454)
Aluminum Alligator...
New/Unused Electric Golf Cart (A57453)
New/Unused...
Troy Built Weedeater (A57454)
Troy Built...
