How often to grease mower deck?
   / How often to grease mower deck? #11
On a related matter, I wouldn't mind the discussion morphing (a little bit) on including *how much* grease to do (for the spindles).
Background: recent (last spring) acquisition of a B7500 (380 hrs) with a RFM-60 rear finishing mower (+ a few more implements). This is my first piece of equipment of this size (altho we live on the old family farm - no acreage in cultivation anymore).
Had to rebuild two spindles immediately - and I pestered the local Kubota dealer on not only greasing intervals (which I ultimately solved after getting the owner's manual) - but also gauging my brain on how much??? There's always this talk about not 'blowing out the seals' (which makes sense) - but it is almost impossible to gauge how much grease 'space' there may be (after packing the spindles during rebuild) - and, thus, how many pumps on the typical hand pump grease gun would be enough and not risk blowing those seals.
Anybody our here that could lend some insight into this?
TIA (Thanks in advance),
-- john.
   / How often to grease mower deck? #12
Is it possible that your deck has sealed bearings? If that were the case, it doesn't need greasing.
It's got grease fittings.
   / How often to grease mower deck? #13
Someone told me overgreasing can blow out the seals?
You can generate around 60,000 psi with a hand pump grease gun. That's what I use to adjust the tracks up on a D6 Dozer. It's really mind blowing to see the dozer move with simple pumps on the handle of a grease gun. With that in mind, how can you possibly know if you are "over-greasing"? I don't now of many seals that will stop your grease gun at those pressures. Excess grease generally squirts or flows out a built in overflow. On the spindles of my Grasshoppers, after a decade of greasing them, I know that I don't drip any grease on my barn floor with 4 pumps but I drop a glob with 5 pumps. So....all these years I've just given each spindle 4 pumps every 8 hours.
Being that none are showing any wear, stupid logic or not, it sure seems to work. On my JD tractors, the ball joint rubber bladders have a weep hole that releases excess grease. I suppose if I pumped away really fast I could split the rubber cover open, but what would be the fun in that? Then I'd have to work on the dern thing. Greasing it every 8 hours is to keep me from having to work on it.
With backhoes and excavators and FEL articulating joints, I stop when I see grease oozing out. There is no seal to blow out. I do go through a lot of paper towels wiping up all my excess grease (yeah, I'm one of those guys), but just like on other things, the practice has served me well. And, yes, I do get grease by the pallet in combinations of 5 gallon pails, cases of tubes and quarter barrels.
   / How often to grease mower deck? #14
You can pump 30 pumps on a B7800 Kunota mower deck and nothing comes out. So how much is too much or not enough and how often?
Mine was factory new.
   / How often to grease mower deck? #15
I grease mine about every 10 hours when I grease the loader and backhoe.
   / How often to grease mower deck? #16
Oh, and that is usually done on a Friday night when I blow the tractor off with air, fill the tank, and check the fluids...;)
   / How often to grease mower deck? #17
LOL. Sorry, but that is plain preposterous. Unless your grease gun comes with a cannon barrel.
I grease MMM spindles every use, 6-8 hours, 5-6 squirts each. Everything else gets greased when deck comes off, never more than twice a season.
   / How often to grease mower deck? #18
Late, typo, a typical grease gun puts grease out at 6,000 PSI. The same applies for what I said. If you never grease anything but the spindles on a routine basis, that is preposterous! It's nothing less than neglect that will shorten the life of the mower. I certainly wouldn't want to buy anything from you. You'll never get equipment to last as long as those of us who grease all grease fittings on a frequent basis.
   / How often to grease mower deck? #19
I have to admit the manual is a little fuzzy...it does say every day, but then somewhere else it refers to every 10 hours. I don't find it all that easy and it's messy as well, so I've taken to greasing it every other mowing. For me that's about every 3 hours of use or so.
   / How often to grease mower deck? #20
All my attachments get a few good shots of grease each time I use them. Grease is way cheaper than replacing parts. Every 10 hours I go over everything clean them up and thoroughly grease everything and have never ran into any problems and my terrain isn't exactly mower friendly.
207270 (A52708)
207270 (A52708)
Jet Ski (A59231)
Jet Ski (A59231)
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
2024 RAM 3500 CAB & CHASSIS (A59575)
2024 RAM 3500 CAB...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56438)
Neckover GL24-2-7K...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
