How strong is a 1533?
   / How strong is a 1533? #11
I had a 2007 1540 Powershuttle with a loader and now have a 2013 1643 Hydro with a loader. For loader work, the Hydro is hard to beat, but for virtually every other task, the Powershuttle is superior.
As far as comparing the two tractors themselves (aside from the difference in transmissions), there are some things that are better on the 1643 (headlights, seat, ROPs that doesn't vibrate near your ear, and one-piece hood) and some things that were better on the 1540 (a quieter tractor overall, better on fuel (both might be as a result of the transmissions, however), and the loader joystick was better than the new one on the 1600 series).
Again, since we use the 1643 more for the loader than as a "puller," the Hydro works well, but I really do miss that Powershuttle.
I also think that my old 1540 would out-pull this new 1643 Hydro.
I agree work you on the power aspect... I had an LS R4041 (41hp) shuttle, and it put much more power to the ground than my R4047 (47hp) HST.
I preferred the shuttle for "constant velocity" jobs like plowing and traveling on the road at speed, but for everything else, I prefer the HST. Even little things like hooking up 3pt implements, are much easier with HST
   / How strong is a 1533? #12
Agreed. If you are pulling a ground-engaging attachment, HST is an inferior transmission choice. We were dragging our pasture with a chain link fence not long ago and I was missing the Powershuttle where I could just find a gear and let it go. Yes, I know the Hydro has "cruise control," but it isn't the same.
You are also right about the preciseness of the Hydro. If you need an inch, you can get that inch, all without slipping a clutch. Hydro is also much faster than a gear transmission (Powershuttle included) when using the loader.
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
20704 (A55853)
20704 (A55853)
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2004 JOHN DEERE 160C LC EXCAVATOR (A59823)
2004 JOHN DEERE...
