how tight should 3pt attachments be?
   / how tight should 3pt attachments be? #21
If the OP is talking about the turnbuckle slop he needs to check the slop when the 3 pt is in the up and down position. On my tractor as I lift an implement the side to side slop at the turnbuckles varies since they are not using the same geometry. Example: When the implement is just off the ground I have an inch or so side to side slop, once lifted all the way there is no side to side slop. If the slop isn't there when the implement is down something (probably the turnbuckle which is the weakest link) is going to break when lifted.
when I hook up the 3pt implements I tighten them in the up position, so I guess that is the right position to make this adjustment.There seems to be a little difference of opinion here between tight and loose, It does seem to make a difference which impliment to tighten and which are better with a little slop. The quick connects seem convieniant, but they will have to wait a little while till I can gather some funds. I probably should do the stabilizers in conjunction with them.
   / how tight should 3pt attachments be? #23
Actually the "telescopic stabilizer" OR the Pat's Quick Hitch would be enough to stop what you described in the original post. You don't really need both. It would be a bit of overkill to have them both. But if the two components can be brought in within budget it would be a sweet set-up.
I'd go with the Pat's if given the choice. However, the telescopic may be more useful if you have several different implements with the lift pins set at different gaps.
   / how tight should 3pt attachments be? #24
I like the telescoping stabilizers WITH the Pat's, the lift arms don't collapse inward like with the turnbuckles and I don't need to use a spreader bar, just set the lower arm width with the telescoping stabilizers and they stay there making hook up easy.
   / how tight should 3pt attachments be? #25
Hmmm.....good point. Expensive but good.
I am not sure what my implement pin distances are, I am going to get out there and check them . I am guessing that they are not the same because it seems that I do alot of wrenching when I switch them.
GWDixon, I would like to see a picture of your spreaders that you made. I will have to do that method for a little while, knowing me, ...it might end up being longer than I think.
   / how tight should 3pt attachments be? #27
If you don't have, or will get, the Pat's then pulling one of the turnbuckle pins on the lower arm will work to keep from excessive wrenching.
The spreaders were made for a Pat's quick hitch and fit into a hole on each hitch component. The adjustable one is just a turnbuckle from the hardware store with a couple of bolts welded on to each end. The solid one is a piece of rod heated and bent. There is another one in stoage that is also solid and was made from 1/4" re-bar. It seems like each of my implements is of a different width.
Thanks, GW, ....that is a great idea, I am going to use that one. I think I will make one for each implement that is a different spacing.
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
2018 Isuzu FTR Landscape Dump Truck (A59230)
2018 Isuzu FTR...
Kubota M4700 (A60462)
48ft all aluminum feather light wedge trailer (A56438)
48ft all aluminum...
2012 TAKEUCHI TL12 SKID STEER (A60429)
2012 TAKEUCHI TL12...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
