How to add hydraulics to a BX
   / How to add hydraulics to a BX #1
bxowner
Vermont
John Deere 5055e
I have a friend who inherited a BX2200 that came only with a mid-mount mower (i.e. no loader, so no joystick). He has an employee who has a BX front blade and quick hitch he's willing to sell inexpensively... can anyone tell me what's necessary to add a valve block to this tractor? Would the blade take the 3-way or 4-way valve? (I assume it'd be better to get the 4-way if the price is close).
Also, he couldn't find a hydraulic pump. I assume the front-end hydraulics are run off the hydro transmission?
   / How to add hydraulics to a BX #2
From my understanding, he would not need the 4-way for a blade, but would for a snow blower, but I agree, best to get the 4-way if possible. I would start with Kubota dealers and see if they can still procure the OEM valve as that would be the best solution depending on price. Here are some part numbers I had in an older wholegoods catalog. I don't know if the BX2200 took either of these loaders. Prices are old.
CHOOSE ONE WITH LA181 OR LA211 LOADER
BX1611* Three (3) Position Control Valve (LA181) 38 $ 481.00
BX1612* Four (4) Position Control Valve (LA181) 40 $ 565.00
Use with Front Quick Hitch Implements (Snowblowers and Front Blades)
BX2013* Three (3) Position Control Valve (LA211) 10 $ 481.00
BX2014* Four (4) Position Control Valve (LA211) 40 $ 565.00
Pump is inside the HST.
   / How to add hydraulics to a BX #3
If the blade has 2 SA (single acting) cylinders, then you MUST have the 4-way valve. Price to do it with aftermarket parts will be about $350- $400, that will include the valve, hoses, QD's and fittings. The mount for the valve would need to be fabricated.
   / How to add hydraulics to a BX #4
If it's the factory blade, it should have a single, double acting cylinder.
   / How to add hydraulics to a BX #5
Just looked at the wholegoods list......... 4 way valve kit is approx. $640.00 which I'd assume would include the valve mount since the kit is required for the front plow or snowblower.
2008 John Deere 9570 STS Combine  Front Duals  Premium Cab  1,704 Sep Hours  Clean & Field-Ready (A48561)
2008 John Deere...
2019 GMC Terrain SLT AWD SUV (A46684)
2019 GMC Terrain...
2022 Mack MD Rollback Truck (A46683)
2022 Mack MD...
John Deere 2950 (A47307)
John Deere 2950...
42in. Skid Steer Forks (A46502)
42in. Skid Steer...
2013 Hyundai Sonata Hybrid Sedan (A46684)
2013 Hyundai...
