How to add hydraulics to a BX
/ How to add hydraulics to a BX #1
bxowner
Gold Member
Vermont
John Deere 5055e
I have a friend who inherited a BX2200 that came only with a mid-mount mower (i.e. no loader, so no joystick). He has an employee who has a BX front blade and quick hitch he's willing to sell inexpensively... can anyone tell me what's necessary to add a valve block to this tractor? Would the blade take the 3-way or 4-way valve? (I assume it'd be better to get the 4-way if the price is close).
Also, he couldn't find a hydraulic pump. I assume the front-end hydraulics are run off the hydro transmission?
/ How to add hydraulics to a BX #2
From my understanding, he would not need the 4-way for a blade, but would for a snow blower, but I agree, best to get the 4-way if possible. I would start with Kubota dealers and see if they can still procure the OEM valve as that would be the best solution depending on price. Here are some part numbers I had in an older wholegoods catalog. I don't know if the BX2200 took either of these loaders. Prices are old.
CHOOSE ONE WITH LA181 OR LA211 LOADER
BX1611* Three (3) Position Control Valve (LA181) 38 $ 481.00
BX1612* Four (4) Position Control Valve (LA181) 40 $ 565.00
Use with Front Quick Hitch Implements (Snowblowers and Front Blades)
BX2013* Three (3) Position Control Valve (LA211) 10 $ 481.00
BX2014* Four (4) Position Control Valve (LA211) 40 $ 565.00
Pump is inside the HST.
/ How to add hydraulics to a BX #3
If the blade has 2 SA (single acting) cylinders, then you MUST have the 4-way valve. Price to do it with aftermarket parts will be about $350- $400, that will include the valve, hoses, QD's and fittings. The mount for the valve would need to be fabricated.
/ How to add hydraulics to a BX #4
If it's the factory blade, it should have a single, double acting cylinder.
/ How to add hydraulics to a BX #5
Just looked at the wholegoods list......... 4 way valve kit is approx. $640.00 which I'd assume would include the valve mount since the kit is required for the front plow or snowblower.
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
Toyota 8BPU15 3,000 LB Stand-On Electric Forklift (A59228)
Toyota 8BPU15...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
40' CONTAINER (A60432)
2020 MACK P164T (A58214)
2020 MACK P164T...
2016 Toro Workman HD-X 4WD Diesel Utility Cart (A59228)
2016 Toro Workman...
