How To Adjust This?
   / How To Adjust This? #21
Might want to invest in some boots.:D
Timber said:
I am also very surprised that the turn buckles are on the outside. I also have a kubota. I am not really familiar with that model. I have to ask are you wheels adjustable to widen your tractor.
I asked the dealer when I was buying the tractor if the back tires could be set in and he said not on this particular model.
   / How To Adjust This? #23
Can you get some straight lift arms? That seems it would give you a little room instead of those z shaped ones. Or maybe swap sides with them, that way they point/angle toward center away from tires instead of out/toward tires. What position are the arms in when the backhoe is on?
   / How To Adjust This? #25
I have the same tractor as Garren with R4 tires and if he has the right spacing on the implement there will be plenty of clearance on the 3pt arms and tires his tiller is set at 32" and that is way too wide.
:p I just caught that...don't worry...I'm the cameraman with steel toe boots.
Those are my neighbors fine sandals you see there in the pic. :D
   / How To Adjust This? #27
tighted those turn buckels up and allow a apprxomately a 1/2 inch of side-to-side sway and your problem will be solved.
   / How To Adjust This? #28
Might want to mention the boots idea to him, since he might need them...
David from jax
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2019 INTERNATIONAL...
Westfield MK130-91 Swing Away Auger (A50514)
Westfield MK130-91...
5-Bottom Plow (A52128)
UNUSED MOWERKING SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED MOWERKING...
Wilrich Field Cultivator (A50515)
Wilrich Field...
Alamo SH88 88" 3pt Flail Mower (A50774)
Alamo SH88 88" 3pt...
