How to bend 1/4" plate into 18" radius?
   / How to bend 1/4" plate into 18" radius? #61
   / How to bend 1/4" plate into 18" radius? #62
Thanks for posting the photo. That is wha got me thinking about this project again.
You are welcome! The scoops work well... I don't know how well they would work in rocky soil though. One with teeth maybe needed then...
Mine is basically like a giant sharp nosed shovel.
   / How to bend 1/4" plate into 18" radius? #63
Are there any propane companies near you. When they take large tanks out of service they usually sell them for scrap. My co-worker picked up a bunch of them a while back for $50 each. They were 36" in diameter and either 1/4 or 5/16 thick.
   / How to bend 1/4" plate into 18" radius? #64
Press brake.
You could have it bent up in under an hour. Locally that'd be $40. Cutting it into segments and welding would cost more than that in materials, let alone time.
   / How to bend 1/4" plate into 18" radius? #65
That's a great idea.
   / How to bend 1/4" plate into 18" radius? #66
Make sure you purge the tank with dry ice or carbon monoxide from a vehicles exhaust before you break out the cutting torch!
   / How to bend 1/4" plate into 18" radius? #67
Here is me bending a piece of plate approximately the same thickness and size as what your wanting to do, actually in the yard, with nothing more than a torch, welder, tape measure, soapstone, and a couple pieces of scrap angle iron. This was a replacement bucket for a 30" pond scoop. David from jax
http://smg.photobucket.com/albums/v177/sandman2234/?action=view&current=MVC-014F-1.jpg
You say you used both torch and welder. Did you bend the angles using heat or did you cut and weld to get the angles?
   / How to bend 1/4" plate into 18" radius? #69
I was wondering the same thing
   / How to bend 1/4" plate into 18" radius? #70
Originally Posted by muddstopper
You probably wont like my suggestion, but I know it will work. If you run a bead of weld the lenght of the metal, it will start to curve. Move over about an inch and run another bead and then repeat until you have the curve you want. Start in the middle of the sheet of metal and alternate from each side of the first weld as you work yourself toward the outer edges. Yep, lots of welding and a rough surface when you are thru, but it will work.
I would imagine just gas heat applied in a similar fashion would work too and be less messy.
Ya, but if ya used hard facing rod...
2021 BOBCAT T870 SKID STEER (A60429)
2021 BOBCAT T870...
2018 Toro Groundsmaster 4000D Batwing Commercial Rotary Mower (A59228)
2018 Toro...
2014 GMC Sierra SLT Crew Cab Pickup Truck (A59230)
2014 GMC Sierra...
UNUSED JCT 72" HYD 4N1 BUCKET (A52706)
UNUSED JCT 72" HYD...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
