How to bend sheet metal and get a proper bend radius
   / How to bend sheet metal and get a proper bend radius #11
When I made and installed my own aluminum facias, eves and trim around our house before I installed our gutters, I made an 8 foot brake from three 2x4s, door hinges and big C-clamps fastened to a table top. You could use a router to chamfer the radius you needed to the board you are bending it around. I bent thin aluminum in 8 foot lengths, but by using heavier wood construction you should be able to bend thicker aluminum material.
   / How to bend sheet metal and get a proper bend radius #12
do not know if it works or not found it the other night looking for some thing else, then read this
Tools
another that caught my eye,
http://toolplans.com/?p=55
   / How to bend sheet metal and get a proper bend radius #13
Since you are a member of EAA buy the home builder books, about 4 books, by Tony Bingelis. He has a lot of useful information and techniques for the home builder. Also go to the Sonex Aircraft website and look for builder's network. You will find other builders who post step by step process of their build. You will find it most helpful
Check out Van's Airforce. While this site is specific for Van model aircraft, there is a lot of good info there for the home builder; aircraft, engines, avionics, painting, tools, etc.
I, once, almost ordered the tail kit for a Van's RV-10. But, I could not give up my Cessna T210. So I am still flying the old bird here and there. I guess it will be the last airplane for me.
   / How to bend sheet metal and get a proper bend radius #14
Here are a couple of tips for working with aluminum sheets. For cutting sheet use your
Router with a 1/4" shank 1/2" dia carbide cutter with a center bearing. Buy an 8' piece of
2" flat bar and DA tape it to the piece on line. Wax the line and cut. Paraffin wax works and is easy to clean off.
Or you can use a end bearing just tape flat bar to the bottom of the sheet.
Also check out Www.lowbucktools.com . I have bought some stuff and it works. I use there
Louvre press. You may want to build the stand an adapt some of the other tools as well.
Propane Tank and 2 Oxygen Tanks (A57454)
Propane Tank and 2...
M998 (A55852)
M998 (A55852)
Stout Brush Grapple (A59814)
Stout Brush...
New/Unused YC-26G Sawmill (A57454)
New/Unused YC-26G...
Kubota L4701 (A53317)
PARTS ONLY - 2023 Ram 1500 Classic Pickup Truck - Hemi 5.7L - Automatic Transmission (A56438)
PARTS ONLY - 2023...
