how to catch crawdads
   / how to catch crawdads #21
Tdog, my first experience with crawfish boils was in '73 when we visited friends in Baton Rouge. He ain't cajun, but she is, and I love her cookin'! There have been a number of so-called Cajun restaurants in Central Texas that I've tried; some pretty good, but not real Louisiana Cajun. However, this past Saturday, some folks had a trailer set up on the H.E.B. grocery store parking lot in Corsicana selling "hot and spicy crawfish" and the guy who cooked them is from Louisiana and knew how to do it! Just wish they weren't so darned expensive.
Bird
   / how to catch crawdads #22
I wonder if you can apply some hydraulic principles here. I have some experience with explosives so had to wonder what would happen if you dug a hole down to the water table in the middle of all these 'funnels'. You could then drop a small explosive charge (or even a cherry bomb) in there and see what happens. It would be most effective if you cover the charge with a good mound of dirt before setting it off to confine the blast - just avoid putting rocks on top (projectiles). I guess you could even use one of the existing holes.
If you size the charge right you should be able to generate an intense enough pressure-wave through the saturated soil to kill the crawdads in their holes. You should get some small spurt of water from nearby holes if you do it right (pressure release) - maybe even eject a couple of mud-bugs if you're lucky.
Seemed like a more fun way to do it than trapping them (course, you wouldn't be able to eat them this way).
RPM - aka - R 'Pyromaniac' M
   / how to catch crawdads #23
Ah ha! He just wants to get em out of the holes. (Wish I'd figured that out earlier, but I was too astonished by the crayfish living in the lawn.)
Have you ever seen a worm prod? I found one at a yard sale for $1.00. Its a metal rod with an insulated handle and an electric cord. You shove the rod into the ground and plug in the electric cord. This applies a mild electrical charge to the soil around the rod. (I've stood on the spot when the thing was plugged in and nothing bad happened--famous last words.)
It works. When you plug that bad boy in, the worms come boiling up out of the ground. I'd suspect it would work with the crayfish too, since they're in the mud, surrounded by water, it might work even better. Or, you could try dropping a couple of water softener pellets down each hole. Probably won't be able to grow much grass there for awhile, but you haven't got a lawn anyway.
SHF
SHF, Well, they're not exactly running around on the lawn. They rarely peak their heads out of their holes. They just make a mess with their tunnels and mounds. It kind of sounds like there isn't anything I can do about them, just like moles.
Easy there with that worm prod. I know a guy who got killed using one. He had the prod in the ground and grabbed his fence while he was waiting for the worms to come out. When he grabbed the fence somehow it completed the circuit (I don't know the exact details or exactly what happened) and that was the end for him.
OK SHF, this worm prod thing sounds interesting! I don't get it though, why was this thing invented? Does it kill the worms or just make them come up out of the ground? If it's the later, then it would be great for catching worms for fishing, so is that what it's for? Where is a good place to look for one, sporting goods store, hardware store, Lowes, ...? I sounds like defective insulation is what killed that guy kubotadriver was referring to.
The water softener pellets sound like they're worth a try too. Will that kill the crawdads? I'm not worried about the grass, since like you said there isn't much of a lawn there anyway, but how long will it be before grass will grow again? What about trees, will water softener pellets hurt them? One of these &*@#$% critters has a hole about 2' from the trunk of a 20' Yellow Poplar that I just paid $75 for a tree spade to move it from the woods to my yard.
   / how to catch crawdads #27
The worm prods are used for gathering worms for fishing. They work great. You wet down the area and stick the prod in. Plug it into an extension cord and out come the worms. Wouldn't have believed it if I hadn't seen it. Will it get out the crayfish? Dunno. Worth a try. If it doesn't, you can at least go fishing.
Water softener pellets are basically salt. I use them here to melt ice with on my porch. They're bigger than rock salt or ice melter so they cut big holes, plus because they are bigger, there's usually some of them left at the bottom of the ice hole, which seems to help future build up. Will it get the crayfish out? Dunno. It worth a shot. The idea is to create a habitat for them that is a little less desireable so they will go elsewhere. I was hoping that raising the salt content might get them to move. I would expect damage to the lawn/trees to depend on how much salt you used. Lots of salt, kill everything, little salt probably not hurt much. They still brine and salt some roads around here in the winter, have for probably 50 years. Stuff still grows on the shoulders, so I thinks its probably going to take a lot of it to kill trees and grass. Still, if the tree is recently transpanted its probably pretty shocky right now and who knows what might happen.
I'd try the worm prod first. Look at tackle/bait/sporting goods shops. There may be one in Northern's catalog, I can't remember. I think the death was probably related to an electric fence. Wet ground, juice in the ground and in the fence. Probably not a good idea to touch both, you'd be making a direct connection from house wiring to house wiring. One of our resident electrical guys might be able to answer that one for you.
Just to throw out another idea. How about a windmill? One of those little ones that they sell for mole control. The vibration might be enough to make the little guys look for someone else's pasture.
SHF
PS the salt won't work if these crayfish are a saltwater variety. Still never saw them anywhere but at the bottom of the lake.
   / how to catch crawdads #28
I think the best thing and safest environmentally is to just boil water and dump 2 gallons down each hole. Be careful and don't burn yourself. Maybe you can fish them already cooked and ready to eat /w3tcompact/icons/smile.gif.
   / how to catch crawdads #29
I've heard lobsters scream when you boil them. Do crayfish scream too? Or just go "OUCH" /w3tcompact/icons/laugh.gif
SHF
   / how to catch crawdads #30
Just another thought. If the area where your crayfish are is real wet and you use and electric worm prod. Use a LOOOONG extension cord, just in case.
SHF
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
207278 (A52708)
207278 (A52708)
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
Forklift (A59228)
Forklift (A59228)
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
