How to Change E4B Engine Back to E3B Specs?
   / How to Change E4B Engine Back to E3B Specs? #1
Rifling8005
Kubota D1105
Hi All,
I have a hydrostatic loader with a Kubota D1105-E4B engine. In Australia, we do not yet have to comply with Euro V or EPA Tier 4 emissions standards, so I would like to bring it back to its former E3B 3600rpm glory, or perhaps even a little more if it is safe to do so.
As far as I can tell from the specs, the only differences are:
D1105-E4B:
18.5kw/24.8hp @ 3000rpm
Max 3200rpm
Injection Timing 18° BTDC
Compression Ratio 24:1
D1105-E3B 3600rpm:
21.7kw/29.1hp @ 3600rpm
Max 3800rpm
Injection Timing 20° BTDC
Compression Ratio 23:1
Can anyone offer any advice on how to go about things?
I saw an old post where SkyPup was talking about changing injector nozzle size a few microns to increase power (Post Here), but I can't find any information on Denso DN0PD injector nozzle hole sizes. As far as I can tell, the original part number for the standard nozzle is 16261-5361-0.
   / How to Change E4B Engine Back to E3B Specs? #2
What are you hoping to achieve?
Enjoy the fuel economy you currently get. A couple of extra HP isn't worth the effort IMHO when you won't be able lift/pull/push much more than you currently can.
I'd invest my time in getting a machine that will do the job instead of trying to up-size a lightweight SCUT that isn't up for the current job at hand.
Unfortunately the only other option I have is a V1505-E4B which... has the exact same power of 18.5kw despite being a bigger, 4 cylinder engine. It is also much more costly.
I don't want the engine to be strung out, I'd just like to regain the power it had before it was hamstrung by EPA4 and Euro V.
(INOPERABLE) CAT D4D (A50854)
(INOPERABLE) CAT...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2018 KENWORTH T680...
2010 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2010 TROXELL...
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
2021 Kubota RTV X900 4x4 Utility Cart (A50322)
2021 Kubota RTV...
