How to choose a portable battery jump starter?
   / How to choose a portable battery jump starter? #32
OK, I will check if Walmart around my place has this kind of jump starter or not. But do not you think 800 Peak Amp is a little low to jump start a car?
Betty, let me end your confusion. I was in the same boat about a month ago. I was set to buy a more expensive, small, lithium ion charger. However, after investigating what was available at my local Walmart, I ended up with this jump starter https://www.walmart.com/ip/Schumach...p-Starter-12V-USB-Power-Supply-Black/54459186.
It has performed flawlessly. However, I opted to spend an extra $5.00 on an extended warranty. I highly recommend this product. I'm very happy with it.
   / How to choose a portable battery jump starter? #35
800 is plenty powerful. I've already used mine to start a truck.
   / How to choose a portable battery jump starter? #37
That depends on how honest the rating really is. 800 amps would crank a diesel pickup with a severely depleted battery. I know for sure a single battery with a rating of around 900 amps will crank a 6.6L Duramax at the proper speed. I kinda doubt a 800 amp battery and an 800 amp peak load jumper box are the same thing.
   / How to choose a portable battery jump starter? #38
Betty,
Check out the Anti-Gravity Micro Start models, this link also has a good video review. They are small, powerful, and can be used for charging many different things. Those large, heavy, portable battery jump starters are old news now. Antigravity Micro-Start XP-1 Power Supply - RevZilla
I believe most places will say how much amp peak rather than the reality.
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
2015 Chevrolet Cruize Sedan (A59231)
2015 Chevrolet...
2018 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A60429)
2018 PRINOTH...
Kubota Snow plow with subframe
Kubota Snow plow...
iDrive TDS-2010H...
Cushman Hauler 1200X Golf Cart (A57148)
Cushman Hauler...
