How to clean deisel injectors?
   / How to clean deisel injectors? #11
How many hours are on the tractor? My old B7100 has 1200 hours and fires right up. The L2550 meter showed 1890, but the meter didn't work and it started fine. The diesel lawn mower reads over 3,000 and it fires right up. My old case 235 had 1000 hours and easily started with no glow plugs, but all the Kubota's don't like to start without glow plugs.
   / How to clean deisel injectors? #12
I'm not so sure your valves would be out enough to cause any starting problems , Good battery? turning it over at a good clip? Run some sea foam threw it and see if that helps you can also put some in your oil.
   / How to clean deisel injectors? #13
If I remember correctly those are Bosch nozzles. They stick the fuel spray pattern gets bad, gets hard to start blows black smoke. Eventually, it will get harder to start, then begin blowing white smoke. Glow plugs won't help. Those nozzles are famous for it. Remove them and have injection shop test them. Not too hard to remove I made a deep well socket just for that nozzle, they are real common nozzle. Hardest part is breaking the injection line loose use a good wrench. last thing you want to do is round that nut over. You may also have to hold the nozzle body from turning. When you remove them there is a brass washer, it may or may not come out with the nozzle. So, you might have to use a o ring pick to get the brass washer out. Those have to be replaced. The injection shop will have those and the rubber/cloth fuel return line. Chances are you will have to cut that. I would not count on injector cleaner working and i don't believe in the stuff. It is a pintle style nozzle, and real susceptible to heat, over time the start to stick. Why they all start doing it at once never been able to figure out for sure. I have seen it where if a machine gets real hot to the point of almost over heating, then they shut machine down real fast. had them do it. You replace the customer's water pump he starts going nuts because his water pump failed got hot and now that that is fixed it is blowing all kinds of black smoke and hard to start. then you tell him his nozzles need to be rebuilt, sometimes its a tuff sell.
   / How to clean deisel injectors? #14
new injectors are cheap now. have an injection shop verify the proper pop pressure and install.
What is the voltage across the starter while cranking?
   / How to clean deisel injectors? #15
ditto on having a proper diesel shop rebuild and pop test the injectors ....
2012 Chevrolet Colorado 4x4 Ext. Cab Pickup Truck (A48081)
2012 Chevrolet...
2018 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
Case 84in Hydraulic Hopper Sweeper/Broom Skid Steer Attachment (A49461)
Case 84in...
2013 Ford F-150 (A50397)
2013 Ford F-150...
2016 Ram 4500 Wheeled Coach Ambulance (A48081)
2016 Ram 4500...
