how to fix FX series 4wd front driveshaft
   / how to fix FX series 4wd front driveshaft #11
I spoke too soon OR Oops, I did it again OR No Good Deed Goes Unpunished.
Today I was donating my time and equipment for charity, working in a creek, digging out sand and rocks and using it to fill flood damaged areas along the creek bank. I had already scooped up all the small rocks and sand and I was working with cantaloupe-size rocks with the front loader. I needed about 10 more buckets full to be finished. Alas, it was not to be.
I was working in mid range, second gear and 4wd and was trying to get the bucket under a fresh load of rock. Simultanously, two things happened. One of the hoses on the bucket tilt cylinders popped and sprayed hydraulic fluid about 20' onto some previously unstained concrete on a bridge floor, and something popped in the front end and the 4wd stopped working.
I don't think it's the drive shaft this time - at least it's not the same driveshaft problem as we've been discussing. There is no rattle-clack of a slipping CV joint. There's no noise at all, just the 4wd won't work in forward or reverse.
I was able to get it out of the creek and back on the transport trailer with 2wd. As soon as I can I'll tear it apart and see what's broken this time. Axle, pinion, spider...maybe we should get up a pool on what's broken.
Stay tuned, this ain't over.
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56438)
2017 Yale GLC050VX...
2000 Ford F-450 Dump Truck, VIN # 1FDXW46F5YEB20130 (A57453)
2000 Ford F-450...
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
2013 Yamaha YDREX4 Electric Cart (A56859)
2013 Yamaha YDREX4...
2001 Ford Explorer SUV (A56859)
2001 Ford Explorer...
2012 DOOSAN G25 GENERATOR (A58214)
2012 DOOSAN G25...
