how to free spin PTO 1735M
   / how to free spin PTO 1735M #11
Yes it wil spin the pto shaft momentarily, only as long as you hold the button in, it is specifically just for pto shaft alignment, that is why it is OUTSIDE the cab on the fender.
That is incorrect. It is there to run implements like a post hole digger. That’s is it’s purpose. I have the same setup on my 1835M and it’s explained in the manual. It is NOT there for PTO alignment and you should never put your hands near the PTO with the tractor running.
With the tractor off, you can turn the shaft by hand if you move the PTO lever to the left of the seat to allow it.
   / how to free spin PTO 1735M #12
Not the case on my Massey
I hold the button until the PTO engages and the it stays on. When I hit the button again the PTO stops spinning. This is how I use my chipper and logging winch without a brick on the seat
Thats interesting that is what I was told by my dealer, but have never actualy used it, another piece of miisinformation I was given I suppose.
I will have to check that out further and play with it when I take the backhoe off and put the snow blower on today.
And I can manually turn my PTO output shaft as long as the PTO lever is a neutral. And I apologize if I passed along some misinformation that I was given.
Informational Lot - Financing (A55315)
Informational Lot...
2020 DRAGON ESP...
72'' rock / skeleton grapple (A56857)
72'' rock /...
2017 BX2680 Sub Compact Utility Tractor (A56435)
2017 BX2680 Sub...
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
