How to get a dropped pipe out of a shallow well?
   / How to get a dropped pipe out of a shallow well? #1
quicksandfarmer
Elite Member
Coastal Rhode Island
Jinma 354, purchased 2007
Well the subject line pretty much says it all.
I have a hand-dug, stone-lined well on my property that is probably over 150 years old. It has a hand pump on it, but it's basically ornamental, a nice spot for a drink on a hot summer's day, but we have a drilled well for the house. Today I noticed it wasn't producing any water, so I lifted the pump to see what was going on, and the bottom section of pipe was missing. The well has a cast concrete cover with about a six inch hole, so I got a flashlight and looked down, the missing piece is sitting at the bottom of the well.
The water level is about 18' down. The pump itself extends about five feet below the surface, then there is an 8' section of black poly pipe and there was a 10' section of PVC pipe with a foot valve on the bottom. That 10' section of PVC is what has fallen off. The PVC fitting had failed so the pipe is smooth at the top. The well is about 3' in diameter, the water is about 5' deep, the pipe is sitting on the bottom about half in, half out, leaning against the side of the well.
My first inclination is just to leave it and go buy another piece of pipe and a foot valve, I could probably be in and out of Home Depot for less than twenty bucks. (In fact, my flashlight peering revealed what looks like two 10' pieces of pipe, I'm not even sure which one is mine.) But is that the TBN spirit? I thought briefly about removing the concrete cap and climbing down the well, but that's just silly. Plus the cap looks like it's been there a long time, I'm not sure if I got it of I'd ever get it back on right.
So does anyone have any tricks for fishing it out? To summarize: a 10' piece of 1" PVC pipe, smooth on the end facing me. About 13-15' down from me. Access is through a 6" diameter hole.
   / How to get a dropped pipe out of a shallow well? #2
Get a 20' piece of 1/4" rebar. Bend the end to a hook shape so that it will slide into the 1" pipe with some restraint but grab into the plastic when pulled up.
   / How to get a dropped pipe out of a shallow well? #3
some reading here
   / How to get a dropped pipe out of a shallow well? #4
Had to do the same thing a few years ago, tool a roll of snare wre and ran it through a 1/2 copper pipe, made the snare and lowered it over the pvc, pulled on the snare wire to lock it and lifted it right out.
   / How to get a dropped pipe out of a shallow well? #5
Had to do the same thing a few years ago, tool a roll of snare wire and ran it through a 1/2 copper pipe, made the snare and lowered it over the pvc, pulled on the snare wire to lock it and lifted it right out.
As we say here, you bet! Elec conduit works too for a few less bucks, or if handy. A burp gun & the right size wheel nut can flare the business end a wee bit. This lets the wire slide easily and can add a biting edge that may require a tad less tension to get a good grip.
btw, Dangle a small flashlight on its own line and 'go in' after dark using the tube to manipulate the noose onto the bit you want hauled out.
'BigRol is your uncle'. :thumbsup:
   / How to get a dropped pipe out of a shallow well? #6
I vote for leaving it at the bottom unless you're terribly curious about what else has accumulated down there over the years.
   / How to get a dropped pipe out of a shallow well? #7
This happened to me a few years ago, but it was about 40' down, and there was about another 60' of pipe that had come unglued.
We contacted a water well digging company and they loaned us a tool they had made. It was basically a cone shaped screw that was attached to more pipe, then lowered into the hole, and stabbed and screwed into the pipe that had broken off.
We were able to raise the old pipe out of the well, but we lost it again later.
We ended up abandoning the well with the broken pipe and just drilled a new well. This was at our deer camp, and the new well cost about $2000
   / How to get a dropped pipe out of a shallow well? #8
Google "well fishing tools" and look at images. Might give some more ideas for making an I expensive fish.
An update: BigRol is indeed my uncle! I didn't have snare wire or copper pipe, but I ran some 12.5 gauge high tension wire through two pieces of PVC electrical conduit. I made a loop at one end of the wire and put a handle at the other. It was pretty easy to get the loop over the pipe, I did it about five times but the pipe kept slipping out. So I put a little bit of electrical tape on the loop to give it some friction and was able to pull it out.
Of course, it was the wrong pipe! My pipe is still down there, its end is in an inaccessible crack in the rocks. I need to make a hook or something to move it around to a spot where I can grab it. I'll try again tomorrow evening.
   / How to get a dropped pipe out of a shallow well? #10
Ah, well fishing:) It requires patience, skill, ingenuity and a more than a little luck.. keep at it.. you will get it.
2020 DRAGON ESP...
2023 CASE 580 SUPER N BACKHOE (A60429)
2023 CASE 580...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A56438)
2019 Krause...
1605 (A57192)
1605 (A57192)
MASSAGE CHAIR (A58214)
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
