How to get a dropped pipe out of a shallow well?
   / How to get a dropped pipe out of a shallow well?
Today's update: I bent a piece of quarter inch steel into a J hook, and taped it to another two sections of PVC conduit. I was able to hook the pipe and move it away from the wall, but every time I let go it would fall back into a crevice. So I recruited my son to hold the hook while I got the snare. He held it while I tried to snare it. It was kind of like doing dental surgery with 20 foot noodles but we eventually coordinated and I grabbed it and out it came.
Some days I feel there's nothing I can't do!
   / How to get a dropped pipe out of a shallow well? #12
Coulda dropped a noose over the pole with the hook.....
   / How to get a dropped pipe out of a shallow well? #13
Perseverance payed off. Good work.:thumbsup:
   / How to get a dropped pipe out of a shallow well? #14
OK, so why dont you just leave it down there and spend your time on something more productive? At least thats what i would do?
   / How to get a dropped pipe out of a shallow well? #15
Satisfaction
   / How to get a dropped pipe out of a shallow well? #16
This job had to be done otherwise you'd be thinking about it at odd hours about how to do it....
   / How to get a dropped pipe out of a shallow well? #17
Once I wanted it out, it would have to come out. Good Job and a lot of good ideas. Congrates
   / How to get a dropped pipe out of a shallow well? #18
I would have pulled the cap off and stuck a rope ladder down there and grabbed it. That's what Grampa might have done back in the day. They actually have a pipe puller tool that well drillers use to get a broken off drop pipe. While you are at it, pull the cylinder and replace the leathers in the foot valve and plunger. That's a fun, satisfying job, too. If the cylinder is brass, you might look up its value. The result may surprize you.
Satisfaction
This.
And this.
And this.
Thanks for sticking up for me. When I break something I feel the need to fix it.
I've already had two people ask me if I was worried about the pipe contaminating the water. I've found the key to not coming off like an *** when someone asks a dumb question is to pretend to think about it, and then say something like, "I don't think that's a problem. Doesn't drinking water flow through water pipes all the time?"
The well is lined with hand-laid fieldstone and the concrete cap sits on top of it. I've learned to be really reluctant to mess with hand-laid stone, if you disturb a stone you can never get it back the way it was.
Sadly the cylinder is cast iron.
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
LAND PRIDE RCR1260 5' ROTARY MOWER (A59823)
LAND PRIDE RCR1260...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1992 Ford L9000 Cab Chassis with Low Mileage Cummins (A56436)
1992 Ford L9000...
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
