How to get key out of ignition!
   / How to get key out of ignition! #1
Christian Haggmark
Hi,
I cant get the key out of the ignition. I just bought a ford 3600 series tractor.
I would really appreciate some help!
Thanks
Christian:)
   / How to get key out of ignition! #2
Is the key bent or broken off in the cylinder? Or, has it just not been removed in a long time?
If the key is still intact, try a shot of spray lubricant into the key slot, wait a short time and GENTLY wiggle the key in a circular motion as you pull straight back. Do not apply direct side to side pressure as this can break the key.
If all the above is not possible( broken key in slot) then you can always remove the switch and let a locksmith take care of the problem. He will also be able to make you a replacement key.
   / How to get key out of ignition! #3
Hi,I cant get the key out of the ignition. I just bought a ford 3600 series tractor.I would really appreciate some help!Thanks
Christian:)
You have to push a button before you can remove the key from my 1989 Nissan pick up.
Check for something like that.
   / How to get key out of ignition! #4
Ford key locks aren't that advanced.. a flat screwdriver or flat nail will turn every one I've ever seen on a thousand series tractor that used the common ford key. same key that starts my 75 ford 5000 starts my 2000 NH 7610s...
if it's rusted in the bore and won't come out.. you can either leave it like it is and think of it as a toggle switch.. or just repalce the key/cyl.. CNh dealer has em on the shelf.
no need for a locksmith for that type of ag-ignition setup...
penetrant oil like pb blaster may help... all depends on how long the key's been in there...
soundguy
Thank you guys!
I got it out! I think it had been in there for a VERY long time!
Thanks
Christian
   / How to get key out of ignition! #8
clean the key up and re-lube the lock before letting them snuggle again..
soundguy
   / How to get key out of ignition! #9
Careful on how you lube these things up. Certain products will crud them up faster than if you just let them be.
   / How to get key out of ignition! #10
There is a specific lube made just for lock cyl's. I'd spray clean it with carb or brake cleaner.. then hit it with some crc electronic cleaner.. then a shot of lock cyl lube... ( usually graphite based and greaseless.).
soundguy
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
2017 FORD F-550 SERVICE TRUCK (A58214)
2017 FORD F-550...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
Teak Wood Dining Table (A59231)
Teak Wood Dining...
KBH Tender Trailer (A56438)
KBH Tender Trailer...
