How to ID class 1 3ph implements
   / How to ID class 1 3ph implements #1
Haywire
Veteran Member
Central Kentucky
Tractorless :(
Newbie 3ph question.
If I go to a farm auction, how do I identify class 1 vs others if it isn't identified? I'd hate to buy something only to find it doesn't fit.
Ian
   / How to ID class 1 3ph implements #2
Got to TractorSmart and then click on the INFO tab then the Three Point Lift Types. This gives all the info you need. The pin size is the quickest.
   / How to ID class 1 3ph implements #3
I'm sure others can tell you more, but basically it's just the size of the pins used/needed to attach it. Cat 0 being the smallest. If your tractor is Cat 1 but you end up buying a implement with Cat 2 which would have larger holes for the pins than your tractor, you would simply use an adapter for the Cat 2 holes. It's just a short sleeve that fits inside the Cat 2 hole with an inside diameter that allows the Cat 1 pins to fit.
   / How to ID class 1 3ph implements #4
Ian
Cat 1 implements will have 3/4" top link pins and 7/8" lower link pins.
Brian
Thanks, I suppose I can just take some pins to the auctions and check for fit.
Ian
   / How to ID class 1 3ph implements #6
Be a little careful of category II implements for a category I hitch. The other difference beside the pin size is the spacing on the lift arms. Category I is 26" center to center of lift point, Category II is 32". That can cause issues with the lift arm length and interference with your rear tires.
thanks, I won't buy anything but cat 1 stuff.
Ian
   / How to ID class 1 3ph implements #8
Yep, pin size is the quickest. Take a tape measure or a set of calipers with you. I can usually tell just by looking. It is not hard to tell the difference between 7/8" lower pins and 1-1/8" pins on a cat II when you have been around them awhile.
And most of the implements in the size you will be looking at will more than likely be cat 1 anyway. A 4' bushhog, 5' blade or boxblade, 5' mower, all are most likely going to be cat 1.
   / How to ID class 1 3ph implements #9
I was always afraid to ask this question but here goes....what class hitch would my 2001 790 be?
2021 Ram 1500 Bighorn (A52748)
2021 Ram 1500...
(6) HD 12' Pipe Gates (A50515)
(6) HD 12' Pipe...
UNUSED AGT KFE-20 ELECTRIC STRAIGHT MAST FORKLIFT (A51243)
UNUSED AGT KFE-20...
ECHO SRM-2210 GAS POWERED WEED EATER (A51244)
ECHO SRM-2210 GAS...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
