how to identify between soft maple and hard maple logs?
   / how to identify between soft maple and hard maple logs?
The bark on a hard maple is lighter colored, plus it's tight and doesn't flake off easily, whereas on a soft maple it has long scales which easily come off. Can you tell the difference in a standing tree with no leaves? If so, go check out a few to see the difference in bark. Small tree can be tough in winter... I once had a licensed professional forester with 30 years of experience insist that the soft maple we were looking at was hard. (The fact that we were in a cedar swamp should have been a giveaway.)
A useless piece of trivia; on a per pound basis all wood has the same amount of BTUs.
Very helpful, thanks. I haven't done much I'd on winter trees but the bark comments I will look into.
Useless trivia? Sure. Interesting none the less. :thumbsup:
   / how to identify between soft maple and hard maple logs? #12
In my area, we have a "soft maple" commonly referred to swamp maple or Manitoba maple. It usually is found around water. When cut, the end of the log has a fairly distinct red ring. This hard wood is actually quite soft and grows very quickly. It is not considered as a desirable fuel wood in my area as it is quite fibrous and burns very quick.
   / how to identify between soft maple and hard maple logs? #13
"The biggest thing I have learned so far is that 5 out of 5 suppliers of split wood I've delt with are crooks in one way or another."
I hear you there!!! I just starting burning 3 years ago and i'm 6 out of 7 were crooks. Taking advantage of this city slicker.
   / how to identify between soft maple and hard maple logs? #14
We call them Swamp Maple here in New England as well. I was surprised to learn that according to a Wiki on the subject, "Acer rubrum (Red Maple, also known as Swamp, Water or Soft Maple), is one of the most common and widespread deciduous trees of eastern North America. The U.S. Forest service recognizes it as the most common variety of tree in America."
   / how to identify between soft maple and hard maple logs? #15
My favorite wood to burn was Black Birch. It also has a sugar content (not as high as sugar maple) and throws some nice btu. I think it was second to hickory in the chart I saw.
   / how to identify between soft maple and hard maple logs? #16
Not all red maple is created equal. The red/swamp/white maple that grows in wet areas is the least useful. Those logs usually have tight, uniform bark with shallow furrows.
I agree. Manitoba maple is nothing more than a weed. Sure, you can burn it after 2 or 3 yrs but it's not the same a soft maple - its worse. It's also very crooked making it easy to ID. The only way you'd ever get Manitoba maple around here is to cut it yourself.
   / how to identify between soft maple and hard maple logs? #18
I no longer have any trouble telling the difference between a hard and soft maple tree. :thumbsup: About five years ago I bought a chainsaw mill. First the color of the leaves in the fall has to do with soil conditions, so that doesn't help much. Second the bark of a soft maple has whorls (circles) that are noticeable, but at some point it helps to have both types of trees within view. The hard maple has a much rougher bark.
I think a lot of the confusion comes from trees being at different stages of growth, of course the trees are of the same species. :cool:
I only mentioned the Chainsaw mill as it's a lot of work (fun work) but I wanted hard maple boards (nicer grain) so making a mistake in tree Identification wastes time. :2cents: If you find a stand of maple trees with both types it will really help. :)
   / how to identify between soft maple and hard maple logs? #19
True. Unfortunately, the volume my stove will hold is limited, so I like to stuff it with the most dense species I can find. Here, that is hickory, white oak, and locust. I'll burn red maple, but it sure isn't my top choice in wood. We have virtually no hard maple around here, find them occasionally from a yard someone planted one in.
   / how to identify between soft maple and hard maple logs? #20
I know what you're referring to. However, the whorls (aka bullseyes) that are so easily identified in your area don't appear in other regions.
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
Tanker Trailer (A59230)
Tanker Trailer...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
2025 GPS Trailers (A56857)
2025 GPS Trailers...
