How to keep from gouging trees
   / How to keep from gouging trees #21
Put electronic sensors like are on the cars for backing up. Then when you get close it will start beeping at you.:D
   / How to keep from gouging trees #22
I have seen some of the pull behind trail mowers with one, two, or three wheels mounted horizontally on the sides of the mower deck. The one at the front corner helps to push the mower away from the tree, while the wheel just rolls on the side of tree protecting it. A picture is worth a thousand words here, but after a quick search, I couldn't locate. Maybe someone here has a pic of what I'm trying to describe??
   / How to keep from gouging trees #23
Like this?
Swisher Products : T-44 Trailmower
   / How to keep from gouging trees #24
Yep, like that! Thanks!!
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
2009 IC Corporation PB105 School Bus (A55973)
2009 IC...
2021 Ford F-250 (A55973)
2021 Ford F-250...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A56435)
BOSS 990 Fuel...
1997 Perkins 75KW Towable Diesel Generator (A56857)
1997 Perkins 75KW...
