How to load trailer with 18 inch high sides with forklift with a long bundle
   / How to load trailer with 18 inch high sides with forklift with a long bundle #1
case580c
Northern California
Kubota M5140 Case 580C, Case 450C, Case 850B John Deere 350C, Kubota L185, Kubota L245H,
I usually place bales of hay on the trailer deck (they come even with the sides) to allow the forklift to just place the palletized load on top of the hay, for instance a palletized bundle of corrugated tin. But I hate having to mess around loading and unloading the hay and raising the center of gravity of the load on my trailer. If I am hauling a long load of beams or anything rigid I usually can just place straps or chains under the beams and place the chains over the forks of the lift and then just place the load on the trailer and then unload with my tractors loader when I get home.
Anyone have any tips on how to load a trailer with 18 in sides with out having to deal with hay bales ?? Thanks Bill
   / How to load trailer with 18 inch high sides with forklift with a long bundle #2
Buy a deckover trailer. It seems like you’ve already figured out the only 2 ways to do it with the current trailer.
   / How to load trailer with 18 inch high sides with forklift with a long bundle #3
Good advice from 4570Man. Make sure you have stake pockets in the deckover trailer and you can add or subtract side sections as needed.
   / How to load trailer with 18 inch high sides with forklift with a long bundle #4
Load the trailer from the rear and use the next pallet to push the first one forward, etc. Or use an empty pallet to do the pushing if you are only loading one. To unload, leave the trailer connected to the tow vehicle and pull the forward pallets back to the rear with a chain until you can reach them with your forks.
Ok, I just reread your post. If the palletized corrugated tin is very long, my suggested method would not work. :rolleyes:
   / How to load trailer with 18 inch high sides with forklift with a long bundle #5
Well, if the idea is to be able to get the long load off again when you get home, then the methods you're using are about it. If you're going to break down and use the load off of the trailer when you get home, you could always just come up beside the trailer with the load, then tip the forks down over the side rail and kind of walk the load off of the forks as you back out of them. Not a great way to be sure.
One of the reasons I'm looking for a 30' deckover gooseneck.
   / How to load trailer with 18 inch high sides with forklift with a long bundle #6
i have metal sides on my trailer and its all welded in. When i need to do a forklift loading - i just grab free pallets from businesses i know of on the way that always give them away. lowes and home depot wont give them away. when i am done i just cut em up for firewood.
   / How to load trailer with 18 inch high sides with forklift with a long bundle #7
You could make some short metal sawhorses just high enough to clear the trailer rim. Position them where the pallet needs to sit, and just take them out when done. I did this so I could get a pallet above the wheel wells in my Datsun pickup.
   / How to load trailer with 18 inch high sides with forklift with a long bundle #8
Long fully palletized loads are easy to load from the rear. With the forklift centered on the pallet, set it on the rear of the trailer and support the free end somehow. Then reposition the forklift to the rear of the load, lift, remove the temporary support and slide it onto the trailer.
I have hauled a lot of barn tin and none of it was ever fully palletized. Rather, it was sandwiched between two 2x4's that were banded. The 2x4's were spaced every so often. We never lifted any of the longer bundles with a standard forklift because the tin was easily bent. In the yard, we used a lift with multiple forks to properly support it.
   / How to load trailer with 18 inch high sides with forklift with a long bundle #9
we use straps to cradle the load- then the strap loops slide over the forks, lift the long bundle over the sides and set it down on the trailer deck- load lumber and metal roofing like this all the time
   / How to load trailer with 18 inch high sides with forklift with a long bundle #10
Cut the sides off.
Schulte SBW800 Rock Windrower (A56435)
Schulte SBW800...
2016 CHEVROLET Express PASSENGER (A56858)
2016 CHEVROLET...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
WOOD GRABBER FOR MINI EXCAVATOR (A58216)
WOOD GRABBER FOR...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58216)
2019 LOAD TRAIL...
(INOP) NEW HOLLAND 6 DISC MOWER (A52708)
(INOP) NEW HOLLAND...
