How to measure fill
   / How to measure fill #11
Some places that don't have their own scales, use the size of the loaders bucket. If they have a 3 yard loader bucket, that's 3 full buckets and a half. In reality, it would be a third if a bucket. It's just hard to walk into the pile and get a third. So it usually ends up being half. That is how a past employer wanted us to load topsoil for customers. By the yard, almost always works out in the customers favor.:thumbsup:
Tonage can be a hard thing too. The size of the load can vary, from the amount of moister in it. 20 tons of stone with 5% moisture is larger than a 20 ton load at 25% moisture. ( Like after a heavy rain)::confused2:
   / How to measure fill #12
I've found that when it is sitting behind the empty truck it never looks like as much as you ordered. When you start filling the wheelbarrows it always seems like twice as much....
Some of the loaders now have scales built into the buckets. My son works at a pavement plant and can set his rig for a set weight and it will automatically dump out any excess when loading the mix hoppers.
Dodge man, Nuffer,
We buy by the yard. They load with a tractor/fel. I guess they eyeball it. I hope it works out even after a few loads.
Pat,
I am now using my new toy, er, tool - a Bobcat 225 w/ fel. I tried the wheelbarrow trick and believe me, it is more than twice the load. http://www.tractorbynet.com/forums/images/smilies/mad.gif
Norm
   / How to measure fill #14
When we got our JD I think that we had 3 wheel barrows. Still do but now they have flowers growing in them as lawn ornaments....
   / How to measure fill #15
Be glade you don't buy sand, gravel, fill, etc. in California. They sell by the ton and the state says they must wet the load so it won't blow out. I live in the hills and see gravel trucks leaving a trail of water as they go up the hill. Some one paid for that water.
   / How to measure fill #16
sand and rock should be sold by the ton
dirt and compost (and bark/mulch) is typically sold by the yard.
sand weighs 1.2Tons per yard (more or less), so he should weigh close to that.
   / How to measure fill #17
Around here it is all by weight.
Min of Transport have mobile weight stations that spot check truckers loads and fine truckers found to be over weight so they tend to carry less than capacity.
Then we have spring thaw laws that down grade capacities as well.
Consequently you want to avoid projects that call for cartage during the thaw as it increases project costs considerably.
   / How to measure fill #18
I sell and deliver topsoil / fill
You dont sell a yard of topsoil by weight. you sell a ton of topsoil by weight.
your comparing apples to oranges
Some smarty will say a yard of topsoil /sand wieghs 1500. if i sold it like that i would make more money but rip 1/2 the people off. a good loader will judge the load by sight on the truck. you can also judge it by loaded bucket but as we all know from using out front end loader its hard to see your loaded bucket or load it full all the time. Most of the guys who have been around for a while will load you heavy.
material all weighs differant amount due to differant density. the differance can really change alot it soils, then on top of it all, moisture content. I just hard 2 feet of snow melt here in WNY in the last 14 days. do you think there would be a differance in weight ?
Most places should also say all deliveries are approx.
Post a pic. of a loaded truck
Best way to know the amount is to watch truck get loaded
   / How to measure fill #19
You mean the People's Republic of California doesn't make the truckers use tarps on their dump beds/trailers? They're used here...when the driver thinks to use it, or the thing isn't beat to crap.
That's the way it's done here too. Also the place I buy from puts its empty trucks on the scale and loads that way to get close to a customer's order. The highest price rip-off chain outfit loads the trucks by eye, then weighs them knowing full well they won't dump the excess before heading out to the customer.
2014 Dodge Avenger Sedan (A50324)
2014 Dodge Avenger...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2003 Honda Element SUV (A50324)
2003 Honda Element...
