How to Plug a tire?
   / How to Plug a tire? #11
haz -
<font color=blue>wordly experience </font color=blue>
oh yeah ... that's right - you don't know him .... great kid ----BUT --- sometimes needs detailed instructions/w3tcompact/icons/hmm.gif must take after his dad /w3tcompact/icons/blush.gif
   / How to Plug a tire? #12
Tractor Supply Co for about ten bucks. Read the instructions and start pluggin holes. It's a piece a cake................
Bartman
   / How to Plug a tire? #13
Hi
I have used plugs in all manner of tyres, they are brilliant. But here down under we have a product called slim that you put in your tyres and when you get puncture it leaks out and blocks off the hole. I ran this for years in the front tyres tubless on a 70 hp Aussie tractor with FEL i think this is a better way to go.
vin
   / How to Plug a tire? #14
vin,
Have you tried that in the rears?
I thought about it but it would seem that my 16x30 rears would require a 55 gallon drum of the stuff?
Fred
   / How to Plug a tire? #15
no i have not tryed it in rears, never had problems with back tyres, i guess because they have more plys.
   / How to Plug a tire? #16
I'm not sure what the guy at the tire shop told you as to the reason he prefered patches on the inside over plugs but I will pass on why i don't use plugs Except in emergency situations.(yes,I keep plugs around) I have had plugs pull completely out of a tire! Doing FEL work in 4x4 shoving the bucket into some piles the fronts started slipping, dug down past the bars(ags) and the exposed end of the plug got traction on a rock and poof! had a flat again. Patches eliminate this problem. rccoyote
   / How to Plug a tire? #17
The plugs I buy around here are already glued and gooey. You just pull a fresh strip from the plastic wrap and thread it through the needle. The glue is very thick and makes it kind of tough to get through the needle but I prefer it.
I used to take me an hour to take my tires off and haul them down to the tire store at $5 a pop. They would put in a plug. Not any more. Takes a couple minutes to fix the flat. What a great tool!
   / How to Plug a tire? #18
Phred,you don`t fill the tires all the way up...not a weight additive.they have a scale that converts tire size to pumps (term used when tire sealent is installed in a shop) probably come out to 1 gal or so...it just coats the inside.probably 6 or 8 large fix-a-flat per tire would work also. My 650x16 cost about $14 each.... Sid
   / How to Plug a tire? #19
Oh an yea guys...food for thought...sealer vurs plugs....if yer way outtinna boonies how are ya gonna get air to air the tire up with?hummmmmmm...think i`ll stick with my pink or green slime and an spare ex large can of fix-a-flat in the tool box...lol ...Sid
   / How to Plug a tire? #20
Speaking of fixaflat, ( which has saved my bacon more times than i care to mention ).. anyone know if someone makes just canned air? No sealant.
There are times when i get a low tire, or do a roadside plug.. but don't want to use the fixaflat as it can throw tire ballance off quite a bit... those times I usually don't have my compressor handy... sure would be nice to have a heavy duty size can of air that screws on just like the fixaflat to air up a low tire... Not quite economical.. but it would have practical applications... for instance... my 12v electric pump won't work when I'm out in the field with my 6v 8N../w3tcompact/icons/eyes.gif
Souundguy
2020 DRAGON ESP...
2025 CFG Industrial SSHH680 Hydraulic Breaker Skid Steer Attachment (A56860)
2025 CFG...
2019 Bomag BMP 8500 Trench Compactor (A57453)
2019 Bomag BMP...
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
