How To Plumb Well Water Lines for 2 Homes
   / How To Plumb Well Water Lines for 2 Homes
Don't hold the brass nut but the fitting the brass nut screws on to. As long as you don't unscrew the brass nut off the fitting the pitless will be held tight to the casing. Teflon tape or pipe dope either will work. I use both with the tape first then dope over the tape. In my opinion Teflon paste is too slick and doesn't let the fitting get tight.
Thank you for the photo.
So that horizontal pipe that sticks out of the pitless has threads on the inside of that pipe to accept the male adapter?
So hold that pipe in place and leave the pitless lock nut alone.
   / How To Plumb Well Water Lines for 2 Homes #63
Yes it has threads. The question is more like if he used a 1" pitless adapter or 1 1/4". Since he used 1 1/4" drop pipe, I would guess he used a 1 1/4" pitless adapter.
Do Not Remove that Brass Nut. That is holding all the weight in the well to keep your pump from falling to the bottom of the well or you could say that it holds it tight to the casing.
   / How To Plumb Well Water Lines for 2 Homes #65
Friction loss is one of the reasons we ran 1.5" mainline for our 1,000 feet that feeds three houses and a shop. Of course, since we are in Florida, we ran PVC and don't have to worry about the "freeze" or "ground thrust" do to changing temps
   / How To Plumb Well Water Lines for 2 Homes #66
Yes, it is a 1 1/4" pitless adapter.
I will make sure the brass nut doesn't move .
   / How To Plumb Well Water Lines for 2 Homes #68
The next question, do you have the tool for 1 1/4" Pex? You need a big hole open far enough to fit the bigger size tool in the hole to crimp the ring.
This brand is my favorite since it has a bigger ID on its pipe but it takes a special high dollar tool to use it. PEX Plumbing, Radiant Heating, and Cooling Tubing Solutions - Uponor
This place has the tools for both kinds. ProPex Expander tool is for the uponor.
PEX Tools , PEX Plumbing Tools , Wirsbo Expander Tool , Wirsbo Tool , PEX Cutter Tool - SupplyHouse.com
Find YouTube videos upondor being used on video - Bing video
   / How To Plumb Well Water Lines for 2 Homes #69
New Holland Workmaster 45 2WD Gear
Massey Ferguson 240
New Holland TC40D HST 4WD
NewHolland 16LA FEL
Woods BH 70-X Sub-frame Backhoe
Troybuilt Super Bronco w/42" mower
Husqvarna DRT 900 Tiller
Ariens 6.5 HP String Mower
Husqvarna HU625WT String Mower
3 point hitch attachments:
single plow, double plow, 5' & 6' deck mower, tiller, 2 cultivators, planter, fertilizer spreader, disk set, sprayer, and a few homemade attachments
30 acres, 15 acres, 5 acres
:thumbsup:
I am going to use SharkBite connections so I don't need the special tool to expand the PEX.
(APPROX 18) 2" X 6" X 68" TUBING (A54756)
(APPROX 18) 2" X...
UNUSED (1) 5200# DROP AXLE W/ BRAKES (A54756)
UNUSED (1) 5200#...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
Galvanized Livestock Gates - (6x Total Gates) (A55218)
Galvanized...
2016 BOBCAT S850 SKID STEER (A52705)
2016 BOBCAT S850...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
