How to remove Battery Cable bolt
   / How to remove Battery Cable bolt #1
JeffandTamara
Kentucky
Kioti DK35, Case 1190
I need to replace the battery in the Kioti Tractor. The Battery cables are a little correded but not that much. I can't get any sockets to fit the bolt. I don't know what the problem is, but no sockets I have metric or SAE will get a bite on the bolts (Pos and Neg) I would like to cut the bolds off somehow. My first choice would be a dermel, but afraid that might go Poof! I know(Hope) there are probably some tricks that someone might have up there sleeve. What do you think??
   / How to remove Battery Cable bolt #2
Wash it down with Baking soda and water a 10mm should fit.
Yes, I thought 10mm should have fit, but it seems to spin on th bolt(s)...
   / How to remove Battery Cable bolt #4
I don't know what the problem is, but no sockets I have metric or SAE will get a bite on the bolts (Pos and Neg) ?
Jeff,
Are you using a deep socket? I need to use one when I am connecting/disconnecting the battery on my tractor.
Steve
Yes,,,deep wells, open end wrenchs, metric and SAE...The bolts are a bit rounded off, Probably what is going on.
   / How to remove Battery Cable bolt #6
Time for vice grips, make sure their tight before turning.
   / How to remove Battery Cable bolt #7
You can try a set of vicegrips.
Sorry, Murph beat me.
   / How to remove Battery Cable bolt #8
That much corrosion, figure on replacing the clamp. Just cut the cable. :)
   / How to remove Battery Cable bolt #9
using a hammer on the socket keep tapping the socket onto the nut, use a good shot of whatever pentrant you have to help, but getting it to start is half the battle, even if you twist/break off the the stud or the nut, your replacing the battery anyways, buy a new nut whan at the store.
   / How to remove Battery Cable bolt #11
heck, im assuming that this is a screw post terminal not a top post?? either way, tap a socket onto the nut and go for it. if its a clamp style/top post cable/connector, try using a dremel to cut the stud in between the to halfs of the connector, cover the battery to prevent sparks from possibly becoming an ignition source
I have some small gear pullers,, maybe I could get one of them on there and see what happens..
I don't think I have enought room to get in there with vice grips... but I have a good small pair...I might see if that would work....
   / How to remove Battery Cable bolt #13
Unhook the other end of the cables and get it out where you can work on it.
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
2019 CATERPILLAR 972M WHEEL LOADER (A60429)
2019 CATERPILLAR...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2020 FREIGHTLINER...
Pemberton 6ft Loader Forks and Frame (A59228)
Pemberton 6ft...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
