How to remove rocks from soil?
   / How to remove rocks from soil? #1
greenmojo
Badger Mountain, WA
John Deere 4300, John Deere 450C
I would love to clear land for a big garden or even some orchard trees and grass, but our property up here is plagued with broken basalt rock spread throughout the top layer of soil.
What is the easiest way to get those rocks out? I bought a rock bucket for my JD 4300, but that's only useful if you are sorting through piles of dirt.
Is there an implement or strategy?
Additionally, I have a JD 450C to push dirt around if that helps with any ideas / strategies you all have.
Thanks,
Moses
   / How to remove rocks from soil? #2
Well they do make rock pickers that are pulled thru the dirt and sift out the rocks and place them in a basket. I have only seen video of them and they may require some loosening up of the soil first, but they do seem to do a good job of cleaning the soil.
   / How to remove rocks from soil? #3
I would hire or rent to get it done,
You need remotes to run a picker and at least 12000# of tractor.
   / How to remove rocks from soil? #4
There are rock rakes that can be pulled behind most any tractor. Naturally they only work on rocks at the surface unless the ground is plowed and soft. The rakes are about the same size as a pull behind grader blade. I have one that is seven feet wide with about thirty five springy tines.
   / How to remove rocks from soil? #5
bucket in left hand, bend over, pick up rock with right hand, put in bucket, walk forward... repeat until bucket is full.
   / How to remove rocks from soil? #6
Rent a 3 pt. Harley Rake. Type in Harley Rake on Google and do some reading.
   / How to remove rocks from soil? #7
We are on heavy land with no stones but i rent some lighter stony land of an old guy who keeps 200acres for himself to keep him occupied and like a lot of the old timers summer fallows half of it but he spends his summers with a reasonable size rock picker on a MF 135 ...he just does'nt fill the basket all the way up , seems to work very well .
Whats wrong with bending your back a bit ...We farm 2000 acres and every year we run through with the front end loader after seeding for 2-3 days and pick 20-30 odd loader bucket fulls by hand from certain fields or new land .
I'm totally confused now, I have a full bucket and there are no more steps. :)
Will do, punching it in now. Thanks.
I don't mind a good ol' workout. I initially started making piles by hand, but then figured some lazy guy with a bad back figured out a smarter way to do this.
Moses.
   / How to remove rocks from soil? #10
Rent a skidsteer with Harley rake on front. Use tractor bucket to remove the rocks to your neighbor's yard at night!:laughing:
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
2020 INTERNATIONAL LT625 SLEEPER (A50854)
2020 INTERNATIONAL...
1985 International X Con Semi (A50514)
1985 International...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump with Hose Reel (A49461)
2025 LandHonor...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A51219)
2012 INTERNATIONAL...
