How to straighten this trailer tailgate?
   / How to straighten this trailer tailgate? #11
I’d put it back on and put I block in the low corner. Then push against the high corner.
Or pull. Come-along or a chain and ratchet binder.
   / How to straighten this trailer tailgate? #12
The come-along idea or ratchet binder would allow you quite of bit of control to get the bending right. Might take a couple of tries but no big deal there.
Took me a while before I could complete this work, but I managed to straighten out the tailgate and get it back on. Had it straightened back in March, but it took me a while before I was able to get around to drilling out one of the broken hinge pins: really difficult; had to break down and get a angle drill.
I pinned one edge of the tailgate with my truck, with a 2x4 along the "fault line," and then used the tractor bucket to push it back into shape. I didn't get real fancy on checking square in which case I wasn't sure that it was going to be good enough until I mounted it.
Tailgate mounted back on the trailer.
   / How to straighten this trailer tailgate? #14
I am such a perfectionist. And have tried hard to repair much bent metal. It stretches. Is there any way to get metal to contract?
   / How to straighten this trailer tailgate? #15
Well you managed to get the trailor almost perfectly framed in the background of that first picture straightening the tailgate.
Nice work all around :)
What sorta complicated this was that this was a rental trailer and it had been pretty beat up, the tailgates, before I got it. At least a couple of the hinges had been re-welded, with the one I had to drill to remove the pin being smaller than the others. The twist was a good 3" when I started.
   / How to straighten this trailer tailgate? #17
Yes. Google "Flame Straightening" and there is a wealth of information. I've done a little - by no means an expert, but it works. Here is an article that shows the basic theory by Tom Lipton. He is an expert:
How flame straightening works | Cutting Tool Engineering
I first learned about it from Shield Arc, who used to post on this site. He's CEP over on WeldingWeb™ - Welding forum for pros and enthusiasts
He claims to be just a hobbyist there, also!
Here is a good example, with pictures:
Flame straightening
2005 KOMATSU GALEO D39PX-21 CRAWLER DOZER (A52709)
2005 KOMATSU GALEO...
2018 Ford F-550 Altec AT48S 47ft Bucket Truck (A55973)
2018 Ford F-550...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Ford F-550 4x4 Terex LT40 40ft. Bucket Truck (A56858)
2018 Ford F-550...
LOT OF TRUCK TIRES (A52708)
LOT OF TRUCK TIRES...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
