how to tell if Head Gasket is blown?
   / how to tell if Head Gasket is blown? #1
Hognosh
N/A
   / how to tell if Head Gasket is blown? #2
Run the engine with the rad cap off. If you see bubbles in the antifreeze that would be a good indication of a blown head gasket. Check your oil and make sure it's not a greyish color. You can also stretch a balloon over the radiator neck and see if it fills up.
   / how to tell if Head Gasket is blown? #3
You could also do a pressure test on your radiator. pump it up and set the pressure and see if it bleeds off. Are you using antifreeze without it leaking. Can you smell antifreeze at the tail pipe? All are good clues.
   / how to tell if Head Gasket is blown? #4
I had this ploblem too look for water in oil.
   / how to tell if Head Gasket is blown? #5
White smoke in the exhaust, and coolant in the oil are two primary indicators.
   / how to tell if Head Gasket is blown? #6
Three ways a head gasket can fail.
1. Cylinder to water jacket.
2. Cylinder to oil passage/pushrod passage
3. Cylinder to air
4. Cylinder to cylinder
No way to pin things down 100% without popping the head. But advise given so far is a good start.
Looking for bubbles in the coolant is a pretty good bet that the gasket is blown into a water jacket. But not seeing bubbles dont rule out the gasket.
Water in oil is also a good indication of being blown, (or cracked block). But clean oil dont rule out the gasket either.
If it were leaking to air, a simple walk around feeling and listening around the head should tell you.
After those quick visual checks, you need to do a compression test. Cause even if all of the visuals pass, it could still be blown cylinder to cylinder.
And even the compression test isnt foolproof. You may show a low cylinder or two, and think that you have a head gasket problem, so pull things appart and it could be something like a busted piston or ring in that cylinder.
So I guess to sum up what I am saying, there is nothing you can do to 100% verify if it is a head gasket short of pulling the head. But there are alot of steps that can help point you in the right direction.
Now if she passes all the tests above including the compression test, I'd be looking elsewhere for the issues you are having. Valve adjustment?
   / how to tell if Head Gasket is blown? #7
Head gaskets keep the combustion gasses in the cylinder and separate from the liquid coolant. A leaking head gasket can leak ;
1) cylinder to cylinder
2) cylinder to coolant
3) cylinder to environment
symptoms can be hard to start if pressure is bled off to adjacent cylinders. Can be coolant out the exhaust or exhaust bubbles in the coolant that you can see in the radiator. Can also be a pulsing sound as cylinder pressure is leaked out between the head and block to the environment.
Pretty easy to determine a bad leak by inspection of the exhaust / radiator flow. A leak down test will tell you more and let you determine which cylinder is leaking and where it is leaking to.
My suspicions are more toward fuel system than head gasket, but from this distance .... its only a guess.
   / how to tell if Head Gasket is blown? #8
I've run into head gaskets burn between cyl.'s as well or into an oil gallery.
They don't always burn into the coolant system.
   / how to tell if Head Gasket is blown? #9
The most reliable way to test for head gasket leakage is to pressurize each cyl. in turn.
While it's not possible to pressurize the cyl's to ignition pressures it is the most reliable way to test head gasket integrity as well as a number of other suspect causes of problems.
Pressurize the cyl's and check for where the air pressure escapes. Simple concept and it works.
But from the op it sounds to me like he's looking in the wrong place for his problems.
   / how to tell if Head Gasket is blown? #10
But even that is still no gaurentee. IF you pressurize a cylinder and get bubbles in the coolant, it "could" be a head gasket. Or it could be a cracked block, or cracked head.
There is NO way to be 100% sure until you pull the head.
I would do some of the checks that people have advised. if any of them checks fail, pull the head and see. But if they all pass, it "could" still be a headgasket, but that would be my last resort to look into. There are far simpler things to check and rule out that could be causing your issues.
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A59904)
2016 INTERNATIONAL...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
1968 Fiat Allis 10c Dozer (A56438)
1968 Fiat Allis...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
2005 Mitsubishi Fuso FE84D Auto Crane 3203 PRX 3,200 LB Crane Utility Truck (A59230)
2005 Mitsubishi...
