How to transition to MIG?
   / How to transition to MIG? #191
Bird nests are only possible if the wire tension dictates. I prefer the feed rolls to slip and or a burn back as opposed to a bird nest.. I do have the frequent slinky blowout when changing wire sizes. The key here is to have as many welders as grinders so you can have all wires ready to go :thumbsup:
   / How to transition to MIG? #192
California you have way more patience than I. If it痴 just a few wraps undone and not kinked I will spool it up. If it痴 more I will most likely make it worse.
I TRY to realize when it痴 time to cut my losses. Lol
Problem is that I don't realize or accept it, until I'm well down the river and there is no turning back.
   / How to transition to MIG? #193
I hate changing wire. Multiple welders is the way to go. Also run 10 pound spools or if running big wire then 33 pounds spools. This saves changing wire.
You have to balance your use. You don't want your wire to corrode do to lack of use.
   / How to transition to MIG? #194
I run .030 for that reason. I struggle with .030 on thin stuff but I am lazy about changing spools. My second MIG will actually probably be a TIG for thin stuff and Aluminum. I don't really need it but... who doesn't want another tool to learn and use.
   / How to transition to MIG? #195
If you TIG for aluminum make sure you have AC. TIG DC is for steel. I am no TIG guy.
I bought a second MIG so I can run .024 wire. There are times when I need it and I don't want to gas weld. TIG is too slow for me. TIG kind of reminds me of gas welding
   / How to transition to MIG? #196
Good points... yes if I pull the trigger, it will definitely be AC. A second MIG is on my wish list but way below upgrading my drill press and jointer. Have them both for sale and when they go the better unit will be quickly on order. Been selling other stuff that hasn't been used in years to fund.
   / How to transition to MIG? #197
   / How to transition to MIG? #198
Yes you have a nice wood working shop. What drill press and jointer you going to get? I have a small wood working shop also. I found a lot of old tools and refurbished them a few years ago. I have an old Delta Unisaw which is like the one I took shop class with back when I was 16. A short list is I have 2 Unisaws, 2 jointers, Atlas floor drill press, old Italian bandsaw, floor mortiser, router table, new Dewalt planer, Ridge table sander, a miter saw and a DC system. I need to sell a Unisaw and a jointer. The second Unisaw is a rare Jr model but I just don't have room for it. My shop has a raised wood floor so it does not lend itself to be a welding shop. I have to do welding out in the garage with a concrete floor.
   / How to transition to MIG? #199
Sorry OP... Thread drift here but to answer your question, cox... I also have a old but not too old 3hp Unisaw. My planer is a 6in delta but want to upgrade to an 8in helical cutter Powermatic 60HH. There are some good deals on scratch and dent that become available every once in awhile. I missed my last chance. My drill press is an old floor standing craftsman. Need to replace the underpowered motor and instead have my eye on brand spanking new Nova (no not a Chevy) but a Voyager. These things are sweet! Direct drive variable speed. Check them out. Need to make sure my shop is set before fixed income hits.
6HH, 8" Jointer, 2HP 1PH with Helical Head
NOVA VOYAGER DVR 18" VARIABLE SPEED DRILL PRESS (SKU 58) - NOVA
You guys snip your birds nests? The couple :) of times I've done that, I wound it back onto the spool.
Maybe flux core isn't as difficult to spool as stiff wire.
Well, the couple I've had have kinked the wire so bad at the feed that it didn't seem like I could fix things without cutting the wire.
Rob
excavator trenching bucket- one bucket per lot (A56436)
excavator...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 BOBCAT T740 SKID STEER (A52709)
2022 BOBCAT T740...
UNUSED FUTURE 513 MASSAGE CHAIR (A58376)
UNUSED FUTURE 513...
2005 CATERPILLAR 906 WHEEL LOADER (A52709)
2005 CATERPILLAR...
2003 Isuzu NPR-HD Truck, VIN # JALC4B14637000853 (A57453)
2003 Isuzu NPR-HD...
