How to weld in a straight line?
   / How to weld in a straight line? #11
You can buy lense covers for your helmet with a magnification made into them. Probably have to go to a welding shop. Would be similar to those reading glasses you can buy at Wal-Mart.
   / How to weld in a straight line? #12
   / How to weld in a straight line? #13
Yes, I'm having a very hard time seeing the weld puddle. Heck of time trying to get my edges to stitch because I can't see them. I find myself over compensating by shoving my face right into the weld.
Cheater lens installed in my auto darkening Miller low end helmet and bright work lights helped me tremendously.
   / How to weld in a straight line? #14
Where'd ya get em?
   / How to weld in a straight line? #15
   / How to weld in a straight line? #16
I find that my eyes are bad enough so it takes very little dirt or smoke on the helmet lens to make it very hard to see. If you do try a cheater lens post back on how much it helps. I've resisted using my glasses while welding simply because my close vision is pretty good while my distance is going. 10 years ago I had just a single prescription but now I have progressives and I don't know how easy it would be to find what angle I need to be looking at for it to be clear. I have toyed with the idea of getting helmet with a larger lens.
   / How to weld in a straight line? #17
Both my helmets have large lenses. I wear bifocal glasses and sometimes struggle a bit getting my head tilted right. Minimal correction for distance. Considerable correction for reading and close work. I'm considering magnification lense in the helmet, then look thru the top part of my glasses?
   / How to weld in a straight line? #18
Ditto - Mag/Cheater Lens. Everyone will get to that point. I like to use Silver Streak or even Silver Pencils for my lines. They light right up with the arc. 3x more than a soap stone.
   / How to weld in a straight line? #20
Shield Arc is the one that first suggested I wore my cheaters... and that was 'eye-opening'...but I hated the viewing head angle they were causing and also the hassle as it meant two operations everytime I put on or took off my helmet! :smiley_aafz:
Mounting the lenses in the helmet was a godsend. :cool2:
2025 GIYI SGB20 20in Single Cylinder Stump Grapple Bucket Skid Steer Attachment (A53421)
2025 GIYI SGB20...
2022 John Deere 9RX 640 Track Tractor (A53485)
2022 John Deere...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
Deere 335P (A53317)
Deere 335P (A53317)
Flat bed utility truck with inline 6Cy engine (A55315)
Flat bed utility...
