How would you flash a roof against board & batten siding?
   / How would you flash a roof against board & batten siding? #21
Is Crain a good name brand tool?
I use a vibratory plunge cutter for getting tile and flooring under door trim. I've always thought it was the best tool for the job. I really like it, but never knew about this one. For brick fireplaces, I've been using a diamond masonry blade on my 4 1/2 inch grinder. That vacuum attachment would really be nice on brick in a clients house!!!
   / How would you flash a roof against board & batten siding? #23
s19, looks good to me! Totally unrelated I reckon, but I'd suggest cutting a whole of them trees down that are close to the barn. I regret leaving trees around my shop/garage when I built it in '92! Now, my highest priority is to cut about 40 huge pine trees away from it!!
   / How would you flash a roof against board & batten siding? #24
Careful examination of an undercut saw shows that it is an angle grinder with a 4" saw blade for close cutting.
They then add an adjustable guide to control the cut height.
If you have a steady hand a regular angle grinder fitted with a 4" blade works just fine.
Also laying the blade on a scrap of flooring works.
23169 (A50324)
23169 (A50324)
(INOP) NEW HOLLAND TS6.120 TRACTOR (A51247)
(INOP) NEW HOLLAND...
2018 KENWORTH T270 SERVICE TRUCK (A51406)
2018 KENWORTH T270...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
RIGID 141 THREADER (A53843)
RIGID 141 THREADER...
2021 CAN-AM OUTLANDER 650 XMR 4-WHEELER (A51406)
2021 CAN-AM...
