Howard Rotavator E50 questions
   / Howard Rotavator E50 questions #1
srjones
Platinum Member
Columbia County, Oregon, USA
Mahindra 2015HST & Mitsubish R1500
A few months ago, I purchased a very used Rotavator which I think is a E series (E50).
For anyone who owns something like this, can you tell me?
1. What are the four speeds of the Selectatilth gears?
2. Why type of gear oil should I use?
3. What (if any adjustments) do I need to make? Grease points?
4. For those who have one of these, do you run them offset, or centered like I'm trying to do?
Thanks in advance,
-Steve
b.u.m.p.
Anybody with a 60's or 70's era Rotavator?
   / Howard Rotavator E50 questions #3
srjones said:
b.u.m.p.
Hi srjones. Just found this forum.
There were four generations of E series:
  • Series I First produced in 1954, and continued to serial no 11628. Single speed only.
  • Series II Serial numbers 11629 to 40000. Selectatilth with redesigned clutch
  • Series III Serial numbers 40001 to 6364776. Recognition feature, cushion drive built into left hand side of rotor. Topmast secured to gearbox by one bolt through cast lug on gearbox.
  • Series IV Serial numbers later than 6364777, recognition feature and safety clutch positioned on the gearbox input shaft.
If you can identify the series, I may have gear ratios and some of the service literature for your tiller.
I believe all Howard tillers recommend SAE 90 oil.
Sean,
Thank you for the information. It looks like it's a Series IV.
I went out and took a closer look at the tag, and I got the following:
Model: EMU 50
Serial: 6365878 F
   / Howard Rotavator E50 questions #5
Talk with the fellows at
Market Farm Implement
257 Fawn Hollow Rd
Friedens, PA 15541
Phone (814) 444-1931
They are experts and very knowledgeable of many implements.
BTW, that tiller is in desperate need of new blades--ask them about that too.
HTH
ARKAYBEE
   / Howard Rotavator E50 questions #6
srjones said:
Sean,
Ok. I looked around and dug up the following --
Here's the operation/service manual for the Howard HE. That should be functionally equivalent to your E Series IV. The maintenance procedures and lubrication points are listed in there:
http://solexcorp.com/manuals/howard/howard_he_manual.pdf
Here's the parts breakdown for Howard E Series IV tillers:
http://solexcorp.com/manuals/howard/howard_e4_parts.pdf
Here is a listing of Howard blades. If you will be using it in abrasive conditions, it is worth using the Superlife tungsten-carbide blades. The initial cost is higher, but will save you money in the long run:
solexcorp.com/manuals/howard/hwdblades.pdf
Your Howard (Kongskilde) distributor in Oregon is now General Implement. Any of your local dealers should be able to get you replacement parts through them. We also stock as many replacement parts for Howard as possible.
Sean, Thank You! Thank you, thank you, thank you! :D
This is the mother lode of info!
Arkaybee, you can't really tell from the picture, but the tines are actually in really good shape. The soils around here aren't really that abrasive (clay mostly)
   / Howard Rotavator E50 questions #8
Sean that is really nice information! I have a Howard H4 works great for me.
regards,
Wayne
It looks pretty close, but to be sure you should find the serial number plate. I can't answer the other questions, but I think your tractor would pull it just fine.
   / Howard Rotavator E50 questions #10
Actually Arkaybee is right, them tines are about whipped.
New Howard tines are are almost square across the cutting edge. I have my brothers 50 in the back of my truck right now, going to do some serious tilling this week, but its the baby tiller
Heres its new Mama
and ST160
2017 JOHN DEERE 323E SKID STEER (A60429)
2017 JOHN DEERE...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A56438)
2018 John Deere...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2020 CAT 308 (A53317)
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
