Howe's Diesel Defender
/ Howe's Diesel Defender #41
glad it has worked for you, & best regards on this open dialogue forum
additives & engine oil will always be a subject of discussion
/ Howe's Diesel Defender #43
The diesel in cold climate areas changes seasonally to have less wax in it to gel during the winter. The only time I've needed an anti-gel additive was when the cold hit hard and early, and I still had summer fuel in the tank.
/ Howe's Diesel Defender #46
1 qt to 30 gallons. Good lube quality and solvent enough to keep things clean.
sounds like ATF works for you. what is the basis of your decision to use, personal experience or what you have read? regards,
/ Howe's Diesel Defender #47
Maybe the main issue with ATF, as I understand it from reading quite a bit on the subject over the years, is that it doesn't really burn well.
It's also not exactly known for being a good lubricant, but more of a detergent.
/ Howe's Diesel Defender #48
Two bottles of Lucas injector cleaner arriving today. In a thread about DPF's elsewhere here a person claimed his short regen cycles were lengthened after using this Lucas product. I'm around 28 hour cycles now with a L4760.
/ Howe's Diesel Defender #49
Looking for a lube cleaner that wasn’t a danger to seals and o- rings
/ Howe's Diesel Defender #50
I posted a link to a small study on this site last year. I think it was from the state of Texas. If I remember correctly, ATF actually scored worse than nothing at all on a wear test 🤷‍♂️
I wouldn’t add it, personally.
In this one too; this HFRR study is the only one of it's kind to happen.
What's surprising is the #1 lubricity additive.
I'm still baffled by those that swear by adding ATF to the fuel tank. ATF is specifically designed to withstand high temperatures, and contains additives that do not burn.
2014 TAKEUCHI TL12 SKID STEER (A60429)
2014 TAKEUCHI TL12...
2020 Nissan Rogue SUV (A59231)
2020 Nissan Rogue...
WHITE PINE TONGUE & GROOVE (A60432)
WHITE PINE TONGUE...
(32) 8" FLOOR TRUSSES (A60432)
(32) 8" FLOOR...
2017 PETERBILT PB337 HYDRA-TAIL FLATBED TRUCK (A59823)
2017 PETERBILT...
(1) UNUSED 31" X 8 MM EXCAVATOR TRACK W/ PIN (A60432)
(1) UNUSED 31" X 8...
