Howse 6"cutter stops cutting, shaft/pto is turning
   / Howse 6"cutter stops cutting, shaft/pto is turning #11
POST A PIC
   / Howse 6"cutter stops cutting, shaft/pto is turning #12
good ideal on the bolts I will do that.. I was looking and the cover comes off from the back?? I take that off all the fluid runs out. Then do i put the grease all around the gears? Now guys Im not the sharpest knief in the drawer on fixing suff...
I was looking these gear boxes are not to high priced.. Id get one just to have a new one and no leaking
Common grease will harden over time and the gear teeth will just hollow out a cavity and not be lubricated.
Year: 2011 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 65,540 Plate: Body Type: 4 (A51694)
Year: 2011 Make...
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
UNUSED FUTURE HYD THUMB CLIP (A51248)
UNUSED FUTURE HYD...
Modine Shop Heater (A51573)
Modine Shop Heater...
(APPROX 14) 3 1/4" X 6" X 68" THICK IRON BEAM (A51247)
(APPROX 14) 3 1/4"...
PAIR OF 7' HOOK ON TRAILER RAMPS (A51247)
PAIR OF 7' HOOK ON...
