Howse Rotary 3pt tiller tines
   / Howse Rotary 3pt tiller tines #1
RitchElbe
Millers Creek, NC
John Deere 4100 / Jim Dandy
Any suggestions of the best place to get tiller tines? I run a 54 inch tiller, probably sees 20 hrs of use a year. After 16 yrs of use.. the tines have fallen fatigued and breaking off
appreciate that reply.. I was looking over their site. I'm actually debating making my own in the shop. Buddy might be able to get a bit of tungsten that I could braze onto the tines.. which would really increase the wear resistance
   / Howse Rotary 3pt tiller tines #4
I would be concerned about them breaking at the weld. Tiller tines like most ground engaging tillage wear parts are formed, the edge put on and then heat treated. They also have a fair amount of leverage out on the end, especially in hard dirt. There is nothing worse than picking tiller tines out of a garden. When I replaced them on my Howard, it was around $10 a tine if I remember correctly.
That's why tungsten is brazed on. Pretty strong connection. I'm a 20 plus year with degree welder. Did something similar with armor over in Kuwait. The armor required CO2 to weld properly, we were out so we went with brazing. It was for a ground scarifier to keep the hard pack leveled out. It was only a drag harrold like item..no really heavy rotating impact. But it all boils down to the availabilty of the material. If I go the usual route..I may do one just to see what happens..
   / Howse Rotary 3pt tiller tines #6
Howard tines are some of the BEST in the business... Lot's of folks try to retro-fit them in their brand of tiller...
For HEAVY DUTY tilling, next problem is the bolts that hold them on. IF you do as much tilling, like I do, you will get a quick lesson in what "quality" bolts are, and how to use them!
SR
   / Howse Rotary 3pt tiller tines #7
Have you inquired at Tillermaxx to see if they have any tines for your Howse? I put some of their tines on my King Kutter ll tiller last yr. I've tilled over 25 acres since with minimal wear on tines.
Will look into that.. thanks!
odd..just attempted a call. and keep getting an Eva Campell... Johnson City is just across the state line from me.. one would think they would have their number right on the web page
   / Howse Rotary 3pt tiller tines #10
Did you call 423-207-1349?
2011 FORD F-150 LARIAT CREW CAB TRUCK (A57192)
2011 FORD F-150...
UNUSED FUTURE MINI EXCAVATOR HYD AUGER (A57193)
UNUSED FUTURE MINI...
UNUSED FUTURE 36C STAD ON SKID STEER (A57192)
UNUSED FUTURE 36C...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
UNUSED JCT 72" HYD BRUSH CUTTER (A57193)
UNUSED JCT 72" HYD...
