HP difference between 3pt and pull type rotary cutters
   / HP difference between 3pt and pull type rotary cutters #21
A few more comments...
They do make a 2596 cutter you may consider. Its a bit lighter, but still 50 HP requirement.
I still think you will be fine with either cutter on that 5240.
As others and myself have said, the requirement isnt really about power, otherwise the pull behind would need just as much. Its about tractor size and heft to handle the cutter.
The L5740 meets the 50HP requirement and is physically identical to your tractor.
The MX5800 meets the requirements and is physically smaller, lighter, and less 3PH lift capacity
A deere 4720 meets the requirements and is smaller with less lift
A deere 5045e is a 1000# heavier tractor and does not meet the requirements of 50hp.
Its not an exact science, and MFG's error on the side of caution. They dont want someone running a 3096 behind a B3200 and tearing up their tractor. With a 5240 and maybe needing some front weights you are going to be fine. Or even leave the loader on if your plan is doing custom mowing. The loader has saved me from running over lots of bad things by keeping it just a skim off the ground.
And if mowing for hire is your goal, consider the issues with trailering a tow-behind unit.
   / HP difference between 3pt and pull type rotary cutters #22
All good points LD
Thanks for everyone's input. Turns out it's a Landpride RCR2596. Emailed him a little over a month ago and he wasn't willing to come down but still available so I gave him another try and we came to an agreement. Picking it up tomorrow..
We will see how it works out. Opted for a 3pt since it should be able to get around some old pins that have grown up way too much.
   / HP difference between 3pt and pull type rotary cutters #24
I think you will like the cutter.
Be sure to post some pics and give us feedback once you get it and get a chance to use it
   / HP difference between 3pt and pull type rotary cutters #25
I'm with LD1, post pics. We love to see what others spend their money on!!! :)
   / HP difference between 3pt and pull type rotary cutters #26
deffinately looking forward to the pics!
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
2013 JLG 8K TELEHANDLER (A58214)
2013 JLG 8K...
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
2018 KOMATSU WA320-8 WHEEL LOADER (A60429)
2018 KOMATSU...
