rlwilliamson
- Joined
- Aug 24, 2011
- Messages
- 3
Little help please. What hp do ya'll reckon is needed for a 6' three point hitch bushog cutting a mix of bermuda and johnson grass?
JimRB (or any one else with a JD 870 or similar tractor!): What are you running for a bush hog behind your JD 870? I ask because I'm in the market for a bush hog and I have the same tractor. I'm looking at a Bush Hog 295 - I know it's a bit heavy duty for my 870 but I want something that will last. I'm currently running a Caroni TM1900 flail mower behind it (that's also a bit big for my tractor but it seems to handle it ok) but need/want a bush hog to take down some (lots, actually!) 2-3" sapplings. I know a Bush Hog Squealer would be a better fit for my JD 870 (28 hp/25 PTO) but really would like the heavier duty Bush Hog 295 model. I also like the medium duty Woods BB600 but I think thats about 150 lbs. heavier then the medium duty Bush Hog 295! Normally, heavier is better but not when you're limited by your tractor size!!!
Ya'll have been most generous with your replies to my post. I usually wait untill my grass gets about a foot tall (Johnson grass about 2'). I want to cut at least 5mph. The reason I wanted a 6' was to get outside my rear wheels. I have a lead on a New Holland TC 29 with 800hrs mfwd but am scared it is a little small.
Also, do ya'll know how much hp is lost, if any, when you have a hydrostat transmission over a geared one?
At present I have an 806 IH which is too big
Can't you rig your 3 point hitch such that a 5 ft mower is angled to one side? That way, you can mow along fences, and will have a clean cut on one side.
