Hello Guys... Remaining Frustrated as I'm back with no real progress to report on this issue IMO...
After taking my
L3940 to the dealer yet again and asking them to check the HST+ specifically, they reported the HP reading at the PTO is right where it should be and that the HST+ trans seemed "normal" to them. I ask if they could check the pressures in the HST+ as I wanted to be sure that there wasn't damage or defect in the trans pump, etc... they didn't indicate anything was wrong and simply said that I had the settings on the HST+ out of whack and shouldn't use the HST+ features when tilling, etc. Not acceptable, IMO...
Recently during spring planting season, we tried to use this 3940 with a 6' tiller... it cuts deeply into the hard, clay soil great with no rpm loss when standing still..., but as soon as you begin to creep forward in LOW/LOW(turtle), the rpm's die and you must lift the 3pt. to a very shallow depth inching slowly to keep it from loading the engine and dying as you move forward... I know that this machine had MUCH more power under load and motion when it was newer... it only has ~ 440 hours on it now. No general fuel, filter or engine performance issues/dealer maintained.
For a better background as to what may be the issue: I hired a son(21) of a friend as a "helper" two years ago and showed him the ropes working with me during that spring/summer.... he did ok under supervision working with me. The following year, I got him started and then checked in with him weekly(I'm 6 hrs. away) as he worked on the farm to plow, till and plant corn, beans, clover, etc. in fields and food plots and then dress the woods roads, etc.
I've since fired him after discovering many lies including not working hours as claimed and waiting until just before I got there to rip around trying to get everything done/mowed from weeks of doing nothing. I found that all of my implements used with this tractor were bent, broken and abused... he was turning with this tractor and implements still in the ground
and I suspect that he severely overloaded the trans in too high a gear/range during that season of abuse.
If I can ask of someone here...
What components should be checked/repaired/replaced in the Hydraulics or HST+ that would have been damaged by this type of abuse and cause this power loss during forward/back movement?
I'm actually to the point where I'm going to trade this machine in on a
L5240 or a used L in higher HP to be able to do the work I need to...
Is it reasonable to expect that an
L3940 should be able to handle a 6' rototiller in the clay soils of SE Ohio??
Thanks so much for your help on this perplexing problem... I love my Kubotas and don't fault the machine although this is getting very frustrating. This is my last shot before getting rid of it and going to something in the 50 HP range... I appreciate anyone's suggestions.
Thanks, Rob
