I absolutely hate recalls and even TSB's. There is SO much mis-information, limited information, lack of information, etc out there on the web.
I have an 05 3500 and an 05 1500. Last recall I got was something about the steering thing, which at the time I believe the letter only effected 03-08 models, and even then, not all of them. It seems if I remember correctly, it had to do with the steering stabilizer, and weather it was attached via a stud through the steering bar, or u-bolts. And I think there was another recall letter about something to do with the front suspension.
I have tried several times to find information on recalls and TSB's and get alot of hit and miss information. And when calling a dealer about parts or whatnot, they never bother to tell you if stuff is covered under a recall or TSB, because they want to sell the part instead of fixing it for free. But I havent found a good reliable source for accurate information (that doesnt require a subscription) regarding recalls and TSB's.
I think one of them was involving the steering geometry change dodge made somewhere around 07 or 08. And going from a y-style to a T-style setup (or vice versa I cant remember). I had just replaced ALL the components for the front steering. All the tierods and links and everything that moves all the way from the pitman arm out to the spindles. Then was getting bits of info on other forums while searching that indicated that if you had issues like I had (ball joint popping out and death wobble) that dodge would upgrade everything to the newer t-style for free. Of course this was after the fact and ofcourse the dodge dealer said they never heard of such a thing.
While I dont follow dodge trucks much, this recall for 08+ is kinda surprising. Since everything I have had to do to mine and the researching I have done all indicated that the 08 and newer ones were fixed since it was a new style steering setup.
